Posted April 7, 200817 yr comment_243302 Hi,I was wondering if anyone could tell me what compression ratio ide have with the following setupf54 block, 86.1 flat tops, p90 shaved 0.030 and 1mm head gasket.Also if someone could post a link to one of the calculators it would be great,Thanks,Jay Link to comment https://www.classiczcars.com/forums/topic/27654-compression-ratio/ Share on other sites More sharing options...
April 9, 200817 yr Author comment_243512 can anyone help me please? Link to comment https://www.classiczcars.com/forums/topic/27654-compression-ratio/#findComment-243512 Share on other sites More sharing options...
April 9, 200817 yr comment_243525 Jason,Have you search the archive? I'm sure there is a load of info about compression ratios for all L28 engine models. Give it a go!Tom Link to comment https://www.classiczcars.com/forums/topic/27654-compression-ratio/#findComment-243525 Share on other sites More sharing options...
April 9, 200817 yr comment_243534 Try this site:http://www.atlanticz.ca/zclub/techtips/calcs/engine%20builder/index.htmlThere are also other Z engine calculators out there. Just search on google. Obviously, it will be a tad higher because of the shaved head.Brettps. And always search, all this stuff is in the archives here, at www.zcar.com and other locations. Link to comment https://www.classiczcars.com/forums/topic/27654-compression-ratio/#findComment-243534 Share on other sites More sharing options...
April 9, 200817 yr Author comment_243541 Ok thanks for that,I did try the search but couldn't find a calculator, Thanks again,Jay Link to comment https://www.classiczcars.com/forums/topic/27654-compression-ratio/#findComment-243541 Share on other sites More sharing options...
April 9, 200817 yr comment_243544 http://www.zcarcreations.com/downloads/lengine.zip Link to comment https://www.classiczcars.com/forums/topic/27654-compression-ratio/#findComment-243544 Share on other sites More sharing options...
