Posted April 10, 200816 yr comment_243696 So I went out to run some errands, backed out of the driveway, then noticed that I couldn't shift into 1st. I got it back in the driveway and it turns out I can't shift into anything other than reverse. Hoping it's something simple and not that I need a new clutch. What do y'all think? Link to comment https://www.classiczcars.com/forums/topic/27693-74-260-only-shifts-into-reverse/ Share on other sites More sharing options...
April 10, 200816 yr comment_243698 Can you shift into any gear when the engine is not even running? The first thing I'd check is the level of fluid in the clutch master cylinder. Link to comment https://www.classiczcars.com/forums/topic/27693-74-260-only-shifts-into-reverse/#findComment-243698 Share on other sites More sharing options...
April 10, 200816 yr Author comment_243700 Yes, I was forgot to add that I can shift when the engine's off. I recently topped off the clutch master cylinder, too.---------------Is there supposed to be oil coming out of the shifter boot? If I push on it, oil comes out, and it was already covered in it before I did anything. I mean the rubber boot at the base of the stick. Not the other one of course. Link to comment https://www.classiczcars.com/forums/topic/27693-74-260-only-shifts-into-reverse/#findComment-243700 Share on other sites More sharing options...
April 10, 200816 yr comment_243705 But with the engine running and the car stationary, you can shift into reverse, but not into any of the other gears? Link to comment https://www.classiczcars.com/forums/topic/27693-74-260-only-shifts-into-reverse/#findComment-243705 Share on other sites More sharing options...
April 10, 200816 yr Author comment_243708 Yes. With the engine running and the car stationary, I can only shift into reverse.I've never had a car with a hydraulic clutch before. I'm assuming the thing on the underside of the clutch that looks like a piston that would pump the fluid into the clutch is just that? Maybe that needs replacing? Because I noticed that the clutch fluid is at the same exact level that it was 3 weeks ago when I changed it out. Link to comment https://www.classiczcars.com/forums/topic/27693-74-260-only-shifts-into-reverse/#findComment-243708 Share on other sites More sharing options...
April 10, 200816 yr comment_243709 I'm having a bit of difficulty pinning this on the clutch if you can shift into reverse. The process for forward and reverse is the same.If the area in front of the car is clear, you could try putting it in first or second with the engine off, then try to start it with the clutch pedal depressed. Be vary cautious with this, as if there is a clutch problem the car could lurch forward even with the pedal depressed. If the car starts normally (no lurching forward), then carefully try to move forward.Please try this and report back what happened.Also, remember that if the car lurches forward when you start it in gear that pressing the clutch WON'T STOP IT. If it starts moving forward, turn off the ignition and stand on the brake! Link to comment https://www.classiczcars.com/forums/topic/27693-74-260-only-shifts-into-reverse/#findComment-243709 Share on other sites More sharing options...
April 10, 200816 yr comment_243710 Also, remember that if the car lurches forward when you start it in gear that pressing the clutch WON'T STOP IT. If it starts moving forward, turn off the ignition and stand on the brake! Link to comment https://www.classiczcars.com/forums/topic/27693-74-260-only-shifts-into-reverse/#findComment-243710 Share on other sites More sharing options...
April 10, 200816 yr Author comment_243711 Alright, I put it into first while the engine was off, and then I started it.....and it lurched forward like crazy and wouldn't start. Now the clutch pedal is really really easy to depress. Link to comment https://www.classiczcars.com/forums/topic/27693-74-260-only-shifts-into-reverse/#findComment-243711 Share on other sites More sharing options...
April 10, 200816 yr comment_243713 OK, I can't quite fathom why you could get reverse, but the clutch is not working. The next step will require a second body. With the engine off, have someone press the pedal in and out while you watch to see if the slave cylinder on the transmission is moving the end of the clutch fork.If the clutch fork moves, something is wrong inside the clutch. But more than likely, you have a stuck piston in the master cylinder, or one or both of the cylinders are bad. Link to comment https://www.classiczcars.com/forums/topic/27693-74-260-only-shifts-into-reverse/#findComment-243713 Share on other sites More sharing options...
April 11, 200816 yr Author comment_243742 Okay, the piston on the slave cylinder moves when the clutch pedal is depressed, but it doesn't seem like it travels very far.Thanks for the help so far, by the way. Link to comment https://www.classiczcars.com/forums/topic/27693-74-260-only-shifts-into-reverse/#findComment-243742 Share on other sites More sharing options...
April 11, 200816 yr comment_243748 Sounds like you have air in the hydraulic system probably caused by a leak. What do you mean by 'changed it out' in your earlier post? You have to bleed a hydraulic clutch like you do brakes. Do you see any evidence of a fluid leak on either the master or the slave cylinder? Your comment "Now the clutch pedal is really really easy to depress" makes me think you have a leak. Link to comment https://www.classiczcars.com/forums/topic/27693-74-260-only-shifts-into-reverse/#findComment-243748 Share on other sites More sharing options...
April 11, 200816 yr Author comment_243752 Yeah, I was kind of wondering that too. And by changed, I mean I siphoned out the old fluid that looked old and nasty and replaced it with new fluid. Like I said, I don't have much experience with hydraulic clutches... Link to comment https://www.classiczcars.com/forums/topic/27693-74-260-only-shifts-into-reverse/#findComment-243752 Share on other sites More sharing options...
