Posted April 12, 200817 yr comment_243892 hey all, looking to swap the gauge face from my 77 tach onto an older (tall skinny typefont) tach. the wire harness is the same (maybe from a 74-75Z (?). it seems necessary to remove the needle to be able to lift off the gauge face....how do you remove the needle?....thanks Link to comment https://www.classiczcars.com/forums/topic/27708-gauge-face-removal/ Share on other sites More sharing options...
April 12, 200817 yr comment_243913 Grab it like a thumb tack and gently pull straight up. If it's anything like the 240Z tach. I had to pull mine to put on the MSA white face gauge kit, that I might add "Sucks". The 240Z tach needle rests at zero so it makes it real esy to set the needle back to zero when re-installing. You'll notice on the below pics that the screws lifted the sticker a little. I think this can be fixed by using a very thin washer for the screw head to turn on, rather than binding on the vinyl. Link to comment https://www.classiczcars.com/forums/topic/27708-gauge-face-removal/#findComment-243913 Share on other sites More sharing options...
April 12, 200817 yr comment_243915 apparently it just prys off Link to comment https://www.classiczcars.com/forums/topic/27708-gauge-face-removal/#findComment-243915 Share on other sites More sharing options...
April 12, 200817 yr Author comment_243924 thanks guys...i'll get out my fingers on it... zs ondabrain: why did the MSA faces suck?...they look good!...outside of the vinyl issue...which quite frankly, i wouldn't have noticed if you didn't say anything ) Link to comment https://www.classiczcars.com/forums/topic/27708-gauge-face-removal/#findComment-243924 Share on other sites More sharing options...
April 12, 200817 yr Author comment_243925 p.s. zs ondabrain...i guess the off-centered thing is bugging you too (larger side gap R vs. L )...they still look good ) Link to comment https://www.classiczcars.com/forums/topic/27708-gauge-face-removal/#findComment-243925 Share on other sites More sharing options...
April 12, 200817 yr Author comment_243929 got it guys...job done Link to comment https://www.classiczcars.com/forums/topic/27708-gauge-face-removal/#findComment-243929 Share on other sites More sharing options...
April 13, 200817 yr comment_243972 They sucked because the vinyl kept peeling up when the gauge got warm. I completely washed and used an alcohol swab on every inch of the faces, and they still peeled.The tach alignment is off,They don't make a Speedo gauge for the early 240Z's, like mine, I had to make my own.Just not happy with the whole $70 purchace and end up having to redo half of them and also make my own.7277, I look at them everyday, hard to NOT notice every detail Link to comment https://www.classiczcars.com/forums/topic/27708-gauge-face-removal/#findComment-243972 Share on other sites More sharing options...
April 13, 200817 yr Author comment_244058 Zs ondabrain: i here ya man. looking at a flaw everyday is annoying....especially the time we Z guys spend on our cars....i bought a brand new dash for my 280, and it came in with a tiny flaw....Pis@%#$ed me off!!! Link to comment https://www.classiczcars.com/forums/topic/27708-gauge-face-removal/#findComment-244058 Share on other sites More sharing options...
