Posted April 13, 200816 yr comment_244028 I was bleeding the brakes on the 240z, everything was going smoothly with the pedal becoming more and more firm each time. When I did the rear left disaster struck; the brake bleeder valve snapped off. It appears to still be in the "closed" position because no fluid is leaking out, so I guess it could be worse, but I am at a loss of what to do. It is nearly flush with the surrounding metal. Has anyone ever had this happen? What do I do about it? Link to comment https://www.classiczcars.com/forums/topic/27719-the-brake-bleeder-valve-broke-off-now-what/ Share on other sites More sharing options...
April 13, 200816 yr comment_244029 Might be able get it with a easy-out. Maybe.. New cylinder would solve the problem don't forget 2 get both sides. Seriously taking it off and chucking it up in a vise will make it easier to work on. Use a flare nut wrench on the brake line. Link to comment https://www.classiczcars.com/forums/topic/27719-the-brake-bleeder-valve-broke-off-now-what/#findComment-244029 Share on other sites More sharing options...
April 13, 200816 yr comment_244030 Craftsman Screw Out, size X1 is what I used on mine when I did that. I was prepared to change the wheel cylinder but that worked. Link to comment https://www.classiczcars.com/forums/topic/27719-the-brake-bleeder-valve-broke-off-now-what/#findComment-244030 Share on other sites More sharing options...
April 13, 200816 yr comment_244031 I just wanted to add that when I broke mine, it wasn't quiite flush. Either way you'll have to pull the cylinder off the car to work with it. Link to comment https://www.classiczcars.com/forums/topic/27719-the-brake-bleeder-valve-broke-off-now-what/#findComment-244031 Share on other sites More sharing options...
April 13, 200816 yr comment_244033 oh-oh! :surprised Next comes the electric brake conversion!! Been fascinated with your project James ever since we talked on the telly. Your "Ampeater" project is electrifyingly timely and has great potential now that it is kinetic! All the best--- Jim D. "Zup" Link to comment https://www.classiczcars.com/forums/topic/27719-the-brake-bleeder-valve-broke-off-now-what/#findComment-244033 Share on other sites More sharing options...
April 13, 200816 yr comment_244035 I bought two wheel cylinders a few weeks ago and they sent the wrong ones. They're the 73-76 style. I have a 70. PM me if you want them. Link to comment https://www.classiczcars.com/forums/topic/27719-the-brake-bleeder-valve-broke-off-now-what/#findComment-244035 Share on other sites More sharing options...
April 13, 200816 yr Author comment_244049 Great advice! Thanks for all the help. I'm going to try the screw remover, didn't even think of that. I was preparing to replace the cylinder too, I hope it doesn't come to that.Zup - I would if I could! I just posted a thread with lots of pics over at hybridz now that I've got something worth showing. Its in the "other engines" forum in case you haven't already seen it.bkelly - Thanks for the offer, but I've got a 70 too. I didn't realize that the 73+ would be different, that is very good to know if I end up changing it out. Link to comment https://www.classiczcars.com/forums/topic/27719-the-brake-bleeder-valve-broke-off-now-what/#findComment-244049 Share on other sites More sharing options...
April 13, 200816 yr comment_244053 another thing when you're installing the new ones.a little coating of antiseize on all the bleeders and brake line fittings. you'll thank yourself if you ever have to disassemble or bleed in the future. Link to comment https://www.classiczcars.com/forums/topic/27719-the-brake-bleeder-valve-broke-off-now-what/#findComment-244053 Share on other sites More sharing options...
