Posted April 15, 200817 yr comment_244200 I searched and found reference to the 2000 issue of Sport Z magazine where the use of aftermarket hoses from McMaster Carr was detailed. Does anyone have a copy of that article or a parts list so I can get the stuff? Thanks Link to comment https://www.classiczcars.com/forums/topic/27734-240z-gas-tank-vent-lianes/ Share on other sites More sharing options...
April 15, 200817 yr comment_244201 I am not sure about that article but here is a post by Arne which is great in explaining the hoses and options http://www.classiczcars.com/forums/showthread.php?t=25857 Link to comment https://www.classiczcars.com/forums/topic/27734-240z-gas-tank-vent-lianes/#findComment-244201 Share on other sites More sharing options...
April 15, 200817 yr comment_244208 Ok, here you go, word for word from the article:All parts listed for this project are available online from McMaster Carr, www.mcmaster.com, which ships even fuel line by the foot. Using McMaster Carr resolved a serious problem I encountered during this repair: finding large-diameter fuel line. If you don’t have any problems procuring a 5/8†I.D. fuel line, then chances are this is not fuel line but heater hose—don’t use it! It isn’t safe to use with fuel. The hose will have a label indicating if it is fuel line. Some items listed here can be found at your local hardware or auto parts store.1 of Part Number 7270K3: polyolefin thick wall adhesive-lined tubing 9†length, black, 1.1†expanded I.D. (used instead of grommets) 6 ft. of Part Number 5645K12: fuel and oil line transfer Buna-N hose SAE30R3, 1/4†I.D., 7/16†O.D., 3†min bend radius 6 ft. of Part Number 5645K24: fuel and oil line transfer Buna-N hose SAE30R3, 3/8†I.D., 19/32†O.D., 4†min bend radius 4 ft. of Part Number 5645K16: fuel and oil line transfer Buna-N hose SAE30R2, 1/2†I.D., 3/4†O.D., 3†min bend radius 6 ft. of Part Number 5645K15: fuel and oil line transfer Buna-N hose SAE30R2, 5/8†I.D., 7/8†O.D., 6†min bend radius 1 ft. of Part Number 54595K21: SAE 100R4 oil suction and return Buna-N hose 3/4†I.D., 1.14†O.D. 1 of Part Number 50295K33: metric steel tubing 12mm I.D., 15mm O.D., 2-meter length Link to comment https://www.classiczcars.com/forums/topic/27734-240z-gas-tank-vent-lianes/#findComment-244208 Share on other sites More sharing options...
April 15, 200817 yr comment_244209 5/8'' gas line can be found at NAPA. Large gas line is sometime use on inboard boats. Sold by the foot and not expensive. Gary Link to comment https://www.classiczcars.com/forums/topic/27734-240z-gas-tank-vent-lianes/#findComment-244209 Share on other sites More sharing options...
April 16, 200817 yr Author comment_244253 Thanks for the list!What is 2 meter long metal tube for? Does it replace a hose somewhere? Link to comment https://www.classiczcars.com/forums/topic/27734-240z-gas-tank-vent-lianes/#findComment-244253 Share on other sites More sharing options...
April 16, 200817 yr Author comment_244254 I figured it out. It's to help bend the hose into shape. Thanks Link to comment https://www.classiczcars.com/forums/topic/27734-240z-gas-tank-vent-lianes/#findComment-244254 Share on other sites More sharing options...
April 16, 200817 yr comment_244265 You can get around using it by making a bigger loop. There is room and it won't effect anything. And since it is hidden, no one will notice. Link to comment https://www.classiczcars.com/forums/topic/27734-240z-gas-tank-vent-lianes/#findComment-244265 Share on other sites More sharing options...
April 16, 200817 yr Author comment_244270 I remember doing that once before. Thanks. I ordered the hoses. I'm trying to get the car ready for the Motorsport Nationals in a week and it's still in the paint shop! I still have an engine and trans to put in. AHHHHHHHH Link to comment https://www.classiczcars.com/forums/topic/27734-240z-gas-tank-vent-lianes/#findComment-244270 Share on other sites More sharing options...
April 16, 200817 yr comment_244271 My advice - don't rush the re-assembly. It's not worth it. Take what ever time you need to do it right. You'll be happier in the long run. Link to comment https://www.classiczcars.com/forums/topic/27734-240z-gas-tank-vent-lianes/#findComment-244271 Share on other sites More sharing options...
