I searched and found reference to the 2000 issue of Sport Z magazine where the use of aftermarket hoses from McMaster Carr was detailed. Does anyone have a copy of that article or a parts list so I can get the stuff?
Thanks
https://www.classiczcars.com/forums/topic/27734-240z-gas-tank-vent-lianes/
Ok, here you go, word for word from the article:
All parts listed for this project are available online from McMaster Carr, www.mcmaster.com, which ships even fuel line by the foot. Using McMaster Carr resolved a serious problem I encountered during this repair: finding large-diameter fuel line. If you don’t have any problems procuring a 5/8” I.D. fuel line, then chances are this is not fuel line but heater hose—don’t use it! It isn’t safe to use with fuel. The hose will have a label indicating if it is fuel line. Some items listed here can be found at your local hardware or auto parts store.
1 of Part Number 7270K3:
polyolefin thick wall adhesive-lined tubing
9” length, black, 1.1” expanded I.D.
(used instead of grommets)
6 ft. of Part Number 5645K12:
fuel and oil line transfer
Buna-N hose SAE30R3, 1/4” I.D.,
7/16” O.D., 3” min bend radius
6 ft. of Part Number 5645K24:
Buna-N hose SAE30R3, 3/8” I.D.,
19/32” O.D., 4” min bend radius
4 ft. of Part Number 5645K16:
Buna-N hose SAE30R2, 1/2” I.D.,
3/4” O.D., 3” min bend radius
6 ft. of Part Number 5645K15:
Buna-N hose SAE30R2, 5/8” I.D.,
7/8” O.D., 6” min bend radius
1 ft. of Part Number 54595K21:
SAE 100R4 oil suction and
return Buna-N hose 3/4” I.D.,
1.14” O.D.
1 of Part Number 50295K33:
metric steel tubing
12mm I.D., 15mm O.D.,
2-meter length
I remember doing that once before. Thanks. I ordered the hoses. I'm trying to get the car ready for the Motorsport Nationals in a week and it's still in the paint shop! I still have an engine and trans to put in. AHHHHHHHH
