evening all , I just took off both front control arms and will be re-re bushing and ball joints . the question is are the control arms identical or is there a right and left side ,I can't seem to find any marks to indicate otherwise . I searched before I posted , but didn't find a answer . I did tag and take pics just in case though .
thanxz
Chris
71-240
https://www.classiczcars.com/forums/topic/27739-front-lower-control-arms/
I think they are indeed identical pressings...BUT you will see that the pivot bush is biased to one side in the LCA.
That then will make the LCA a LEFT or RIGHT fitting.
[The narrow side faces the front]
