Email logins are now active ×
Tranny Swap. How to get the speedo correct?
kcoke
The speedo gear is matched to the rear-end gearing. So just use the speedo gear out of your stock 4spd. You may have to swap the speedo gear carrier... using the gear itself from your original 4spd., but put in the ZX speedo gear carrier. As I recall there is a "pin" that holds the speedo gear in the speedo gear carrier. (the carrier bolts into the transmission - and speedo gear is inside the carrier).
If you have changed the rear gear ratio - then you need a speedo gear to match it.
FWIW,
Carl B.
  • Who's Online   0 Members, 0 Anonymous, 176 Guests (See full list)
