Posted April 21, 200817 yr comment_244783 Hi,I've been using this for about 4 / 5 months now, though I would sharehttp://www.14point7.com/JAW/JAW.htmNigel Link to comment https://www.classiczcars.com/forums/topic/27794-cheap-wideband-o2-sensor/ Share on other sites More sharing options...
April 21, 200817 yr comment_244803 I know what 'AFR' is but what is 'lambda'? Link to comment https://www.classiczcars.com/forums/topic/27794-cheap-wideband-o2-sensor/#findComment-244803 Share on other sites More sharing options...
April 21, 200817 yr comment_244837 change? Link to comment https://www.classiczcars.com/forums/topic/27794-cheap-wideband-o2-sensor/#findComment-244837 Share on other sites More sharing options...
April 22, 200817 yr Author comment_244869 sblake01 said: I know what 'AFR' is but what is 'lambda'?I found this,http://forums.evolutionm.net/showthread.php?t=199703here's a snippetLambda just means stoich for the fuel mixture.gasoline stoich AFR = 14.7Lambda = 1.0AFR = 11.76Lambda = 0.8Lambda is basically just the multiplier to the AFR. From what I've read is we all use AFR to measure mixture but people in other countries like to use lambda. Some rather use lambda while others like to use AFRs. Hopefully you can actually change what the your unit displays(either lambda or AFR.)I suppose this is like PSI and Bar with Turbo peopleNigel Link to comment https://www.classiczcars.com/forums/topic/27794-cheap-wideband-o2-sensor/#findComment-244869 Share on other sites More sharing options...
