Posted April 23, 200816 yr comment_244995 Ok I was going to use the same heater valve but then i broke the little copper hose on the valve. what is the copper hose for and do i really need it??? This heater job is about to drive me crazy!!!:mad: Link to comment https://www.classiczcars.com/forums/topic/27825-heater-valve/ Share on other sites More sharing options...
April 23, 200816 yr comment_244998 Umm, the copper tube is what makes it work. I think you need a new one. Link to comment https://www.classiczcars.com/forums/topic/27825-heater-valve/#findComment-244998 Share on other sites More sharing options...
April 23, 200816 yr Author comment_245002 Man! And I bet that its going to be a hard to find part. What does this part do??? I have had this car for a week and im already wanting to get read of it if this takes any longer! Link to comment https://www.classiczcars.com/forums/topic/27825-heater-valve/#findComment-245002 Share on other sites More sharing options...
April 23, 200816 yr comment_245005 It either lets hot water into the heater core or bypasses it depending on where it's set. Without the tube intact you'll either have heat all of the time or not at all or somewhere inbetween depending where it was when the tube broke but you wont have control of that without the tube. Link to comment https://www.classiczcars.com/forums/topic/27825-heater-valve/#findComment-245005 Share on other sites More sharing options...
April 23, 200816 yr Author comment_245006 Is there a more simple newer way of doing this??? Im affraid that i will just break a new one again. It would be nice if there is a universal heater core valve out there that does not have the copper tube. Link to comment https://www.classiczcars.com/forums/topic/27825-heater-valve/#findComment-245006 Share on other sites More sharing options...
April 23, 200816 yr comment_245007 oops---didn't look at the pic closely enough---your in a 76 ZMy Bad! Link to comment https://www.classiczcars.com/forums/topic/27825-heater-valve/#findComment-245007 Share on other sites More sharing options...
April 23, 200816 yr comment_245010 Check with Oliver at Zmanofwashington--- he rebuilds these for your model/year Zcar and should have one in stock. Jim D. "Zup" Link to comment https://www.classiczcars.com/forums/topic/27825-heater-valve/#findComment-245010 Share on other sites More sharing options...
April 23, 200816 yr comment_245014 Check with Oliver at Zmanofwashington---he rebuilds these for your model/year Zcar and should have one in stock. Jim D. "Zup" I posted the link in your other thread. Link to comment https://www.classiczcars.com/forums/topic/27825-heater-valve/#findComment-245014 Share on other sites More sharing options...
April 23, 200816 yr Author comment_245020 would it hurt just putting a universal valve on there instead of spending tons of money on some original part that might just break again??? Link to comment https://www.classiczcars.com/forums/topic/27825-heater-valve/#findComment-245020 Share on other sites More sharing options...
