Posted April 24, 200817 yr comment_245119 I have replaced all of the gas tank vent hoses (all 5 for a CA car!!!). I'm trying to get the evap tank back in the well. Do the large vent hoses go behind or in front of the filler neck? I'm fighting it big-timeCan I eliminate the evap tank on a CA car? The gas tank has 4 hoses coming from it. Link to comment https://www.classiczcars.com/forums/topic/27840-gas-tank-vent-hose-routing-evap-tank/ Share on other sites More sharing options...
April 24, 200817 yr Author comment_245138 Got it. They go behind the filler neck. Link to comment https://www.classiczcars.com/forums/topic/27840-gas-tank-vent-hose-routing-evap-tank/#findComment-245138 Share on other sites More sharing options...
April 24, 200817 yr comment_245190 Yes, you can eliminate the evap tank. I have built and installed a "manifold" that sits above the tank, that connects all the various tubing.[edit] anyone want a plastic evap tank? [/edit] Link to comment https://www.classiczcars.com/forums/topic/27840-gas-tank-vent-hose-routing-evap-tank/#findComment-245190 Share on other sites More sharing options...
