MDS-280zx dizzy-magnetic pickup-tach?
MikeyZee
Hey All,
Just gotta tell you with all the info here I got the 240 to fire right up with the 280 dizzy. I even found a few threads on NOT using the spendy little 12-80 module. It works great! With the 12-80 module I would have to use the Weber starting procedures (two pedal pumps and third pedal to start). With the 12-80 module removed using the magnetic pickup from my MSD 6 connected to the 280's dizzy green and red wires it fires with no choke, no pedal pumps, no one third pedal! Fires up with less than a full crank too! I'm sold on that configuration! (I'll post schematics and pics later) But my tach does not work!!!!! LOL
I'm guessing I need the MSD 8910 tach adaptor. The docs I have seen show to hook it up using the switched power (black/white) and the white from the MSD. This is for when you are using the 12-80 module and the white goes to the module. I am not using the white I am using the magnetic pickup (green+violet). Anyone have an idea on how to get that working? Thanks again everyone. BTW....I have two 12-80 modules for sale!!!! anyone? anyone?
Mike
Well...I'm still a little confused about this.
I had the e12-80 working and the tach working just fine.
Now the tach wire (black/white) that was hooked to the + Coil is now hooked to the Red switched power for the MSD box. Now.....couldn't I just find another switched 12v to power the MSD and hook that black/white back up to the coil + and get my tach back?
  • Who's Online   2 Members, 0 Anonymous, 802 Guests (See full list)
