Posted April 26, 200817 yr comment_245395 Hi all, I've been slowly getting the bits I need for my rear disc conversion, I had my brackets made (laser cut), and I threaded them, also I had my brother spin down the "tab" to make a 4mm offset to centre the caliper to the disc, as you can see they fit pretty good (on my spare 240k). also here's a link to my web site with more pictures http://noddle.110mb.com/Rear%20Disc%20Conversion/index.html Nigel Link to comment https://www.classiczcars.com/forums/topic/27875-my-rear-disc-conversion/ Share on other sites More sharing options...
April 27, 200817 yr comment_245446 looking good, great work! how close did your calipers end up being compared to the set i have?Kent Link to comment https://www.classiczcars.com/forums/topic/27875-my-rear-disc-conversion/#findComment-245446 Share on other sites More sharing options...
April 27, 200817 yr Author comment_245492 Hi,I used "240K&Beyond" original CAD drawing, from this thread http://www.classiczcars.com/forums/showthread.php?t=15930&highlight=bracket+240Kit was a one piece bracket, there is no one around where I live, that could do a C&C bracket for me, (cheap enough anyway)all I did was "hack" it so it was in two pieces, it cost me $37 to get the two sides made (4 pieces)and all I have to do is bolt the two half's together, the engineering place offered to weld them, but I preferred to bolt them as I saw it would be easier to get them passed by a engineer .I'm sure if anyone wants the original CAD drawing, 240K&Beyond, would be happy to give you a copyNigel Link to comment https://www.classiczcars.com/forums/topic/27875-my-rear-disc-conversion/#findComment-245492 Share on other sites More sharing options...
April 29, 200817 yr Author comment_245587 This is the CAD drawing for my bracket, it was based on 240K&Beyond original CAD drawing.Disc Bracket 240K-Bolt.dwg Link to comment https://www.classiczcars.com/forums/topic/27875-my-rear-disc-conversion/#findComment-245587 Share on other sites More sharing options...
May 15, 200816 yr comment_247463 Looking good Nigel, how much better does it brake with the rear discs on it? is it very noticible Link to comment https://www.classiczcars.com/forums/topic/27875-my-rear-disc-conversion/#findComment-247463 Share on other sites More sharing options...
May 16, 200816 yr Author comment_247553 I haven't finished it yet, I have been busy doing other stuff, and now with the weather getting worse (cold and wet) and getting darker sooner (don't forget I live in Tassie), I haven't got back to it yet, also you may have noticed, I have about 3 other jobs on, on my 240KIf you check out my web site, I put a lot of picture up on it.http://noddle.110mb.com/Nigel Link to comment https://www.classiczcars.com/forums/topic/27875-my-rear-disc-conversion/#findComment-247553 Share on other sites More sharing options...
May 16, 200816 yr comment_247582 Just checked your site out, Turbo upgrade! wicked :love: You've done really well Noodle, I'm impressed Link to comment https://www.classiczcars.com/forums/topic/27875-my-rear-disc-conversion/#findComment-247582 Share on other sites More sharing options...
May 17, 200816 yr Author comment_247744 240kconvertible said: Just checked your site out,Turbo upgrade! wicked :love: You've done really well Noodle, I'm impressed Thanks you, and I added some more stuff to my site, all I need to do, is to finish my projects .. Nigel Link to comment https://www.classiczcars.com/forums/topic/27875-my-rear-disc-conversion/#findComment-247744 Share on other sites More sharing options...
May 22, 200816 yr comment_248342 Noddle said: Thanks you,and I added some more stuff to my site, all I need to do, is to finish my projects ..NigelDon't we all need to finish our projects, 2012 guys lets all try and make it there. Link to comment https://www.classiczcars.com/forums/topic/27875-my-rear-disc-conversion/#findComment-248342 Share on other sites More sharing options...
October 11, 200816 yr comment_263071 I have a set of ventilated rotors and mounting brackets to convert to disk brake rear end if anyone wants them. (free) They have no calipers at the moment. This is not the best setup in the world, for a number of reasons. the rotors were Chrysler Centura 6Cly fronts. (rare as rocking horse poo these days, so hard to replace, but there's an Audi one which you can use) they've been turned down in diametre by about 10MM (this allows them to fit inside the standard 14"steel rim) they use Commodore VB front calipers. This means you have no handbrake unless you use a hydraulic one. you can buy VB calipers from wreckers for about $50. The mounting brackets are something I made myself. hmmm.....smacks of quality doesn't it? . but they work fine. I used this setup on my rally car for about 6 years. they were fine. the reason I changed them was that the calipers sat on the top. In rally use the dust used to sit on the caliper and cause it to get really hot. you also had to take that caliper off to bleed the brakes, not that that's a big drama. So I figured since I no longer had 14" rims, I might just as well build new brakes that fit the caliper at the back. other than that the brakes on my car are the same as these. I'm chucking them over the tip if I still have them next weekend, but if anyone thinks they might have a use for them, please let me know. Matt. Link to comment https://www.classiczcars.com/forums/topic/27875-my-rear-disc-conversion/#findComment-263071 Share on other sites More sharing options...
