Hi, i Just try my new harness and unfortunatly it didn't work, i discovered that i'm not getting any spark from the coil, this i what i have build and connected so far:
IGNITION SWITCH
1.- from the IG switch to the starter (BY black-yellow)
2.- From the IG switch to the fuse box (BW black-white)
3.- from the IG switch to the Ammeter, to fuse box (WR white-red)
4.- from the IG switch to the fuse box (LR blue-red)
5.- from the IG switch to the tachometer (GW green-white)
COIL:
1.- from the + coil to the tachometer(BW black white)
2.- from the - coil to the distributor
Note: the coil make a loop from the BW with the ignition switch GW
ALTERNATOR:
1.- From the Alternator to the fuse box (WR white-red)
2.- From the Alternator to the Ammeter (WR white-red)
3.- From the Alternator to the Ignition switch (WR white-red)
Note the alternator goes to the IG switch in point 3
VOL. REGULATOR:
1.- From the Vol. regulator to the Alternator (Y Yellow)
2.- From the Vol. regulator to the Alternator (WB white-black)
3.- From the Vol. regulator to ground (B black)
4.- From the Vol. regulator to the Starter and into the ammeter and fuse box (W white)
I am telling you as much as i can and i am writting the original color (I have diferet colors since i'm making the harness)
I dicovered i had no spark from the coil to the alternator paceng the cable that goes from the coil to the alternator to ground and i was expecting a spark but nothing happened, the i place the coil directly from the battery and still the same i measure with a volt meter and i read read 8.8 omhs axbetween the coil terminals
The battery was fully charge
any ideas what to check next?
i will appreciate any help
thank you all
72 240z
Mexico City
https://www.classiczcars.com/forums/topic/27947-wont-start-new-harness/
