Posted May 2, 200816 yr comment_245979 Hi, does anybody if a 72 240z hava an Electric fuel pump? Link to comment https://www.classiczcars.com/forums/topic/27954-fuel-pump/ Share on other sites More sharing options...
May 2, 200816 yr comment_245985 Mechancal. I think some were dealer fitted with an extra electrical for vaper lock. Link to comment https://www.classiczcars.com/forums/topic/27954-fuel-pump/#findComment-245985 Share on other sites More sharing options...
May 2, 200816 yr comment_245990 Well you put this thread in the 'fuel injection systems' section for whatever reason but I can give you a better answer than the last. The simple answer is NO. No 72s had electric fuel pumps. That modification came in 73. Link to comment https://www.classiczcars.com/forums/topic/27954-fuel-pump/#findComment-245990 Share on other sites More sharing options...
May 2, 200816 yr comment_246005 As a point of note, the 1972s did come wired for an electric fuel pump. Link to comment https://www.classiczcars.com/forums/topic/27954-fuel-pump/#findComment-246005 Share on other sites More sharing options...
May 2, 200816 yr comment_246026 As a point of note, the 1972s did come wired for an electric fuel pump.I almost mentioned that but, remember, I was trying to give the 'simple answer':classic: Link to comment https://www.classiczcars.com/forums/topic/27954-fuel-pump/#findComment-246026 Share on other sites More sharing options...
