I am stripping out my 280Z for repainting. I tried to take out the front screen last night in the way described in Haynes but cracked it:( Before I try and get the replacement screen out of my parts car .... any advice???
Thanks
https://www.classiczcars.com/forums/topic/2797-glass-removal/
Rasorblade slice the rubber from the inside. Cut it at the glass and at the frame. It should be sitting free when you are done cutting. Lift the glass out using suction cups ( 2 req'd w/ 2 people ) It worked well for me on mine.
Guest
Reply to this topic...
