Posted May 8, 200816 yr comment_246663 has anyone had any luck with finding air filer elements with any of big auto part chains? Link to comment https://www.classiczcars.com/forums/topic/28036-air-filter-element-availability/ Share on other sites More sharing options...
May 8, 200816 yr comment_246670 $14.05 tax sack and all at O'Reilly Autoparts Fits fine---Wix brand HTH Jim D. "Zup" Link to comment https://www.classiczcars.com/forums/topic/28036-air-filter-element-availability/#findComment-246670 Share on other sites More sharing options...
May 8, 200816 yr comment_246677 FWIW Wix is good stuff. Can't go wrong..... Link to comment https://www.classiczcars.com/forums/topic/28036-air-filter-element-availability/#findComment-246677 Share on other sites More sharing options...
May 8, 200816 yr comment_246679 Here the local AutoZone carries an STP and a Fram element for no more than $7 or so. Link to comment https://www.classiczcars.com/forums/topic/28036-air-filter-element-availability/#findComment-246679 Share on other sites More sharing options...
May 8, 200816 yr comment_246694 240z/260z or 280z? There is a difference. Link to comment https://www.classiczcars.com/forums/topic/28036-air-filter-element-availability/#findComment-246694 Share on other sites More sharing options...
May 8, 200816 yr comment_246696 twsutt said: 240z/260z or 280z? There is a difference.Actually the 1970-72 air filter is different than the 1973-74 one. When Nissan switched to the flat-top SU’s these carbs had more depth and hence the air filter element was reduced in height on the ’73 and ’74 S30 models so the overall depth of the carb plus air filter would be the same. Link to comment https://www.classiczcars.com/forums/topic/28036-air-filter-element-availability/#findComment-246696 Share on other sites More sharing options...
May 8, 200816 yr Author comment_246702 actually, it is a 73 240z, but i'm in the process of updating the car with a set of ztherapy su's and boxing my hitachis. Link to comment https://www.classiczcars.com/forums/topic/28036-air-filter-element-availability/#findComment-246702 Share on other sites More sharing options...
May 9, 200816 yr comment_246720 Napa, Schuck's/Kragen, and SummitRacing all carry 240 filters in the low teens ($). Link to comment https://www.classiczcars.com/forums/topic/28036-air-filter-element-availability/#findComment-246720 Share on other sites More sharing options...
May 9, 200816 yr comment_246742 If you want a K & N for the origional early air cleaner '70-'72 the part number is E-2910 I ordered mine form Summit Racing. Gary Link to comment https://www.classiczcars.com/forums/topic/28036-air-filter-element-availability/#findComment-246742 Share on other sites More sharing options...
May 9, 200816 yr comment_246743 Gary's post with the part number given is the most informative one on this thread. Post the part numbers guys! Otherwise people show up at the stores you mention, ask for the item and are told.... "If it's not on the shelf, then we don't have it." 2¢E Link to comment https://www.classiczcars.com/forums/topic/28036-air-filter-element-availability/#findComment-246743 Share on other sites More sharing options...
May 9, 200816 yr comment_246747 NISSAN 16546-E3210 (In stock at Nissan Parts.cc)$14.94+$9.95shOEM is also shown as 16546-00006 at Courtesy Nissan $16.93+shAC A827C FRAM CA2749 MOTORCRAFT FA758 PURO A33544 WIX 42293BECK ARNLEY 0428201 Link to comment https://www.classiczcars.com/forums/topic/28036-air-filter-element-availability/#findComment-246747 Share on other sites More sharing options...
May 9, 200816 yr comment_246775 Stephen .... EXCELLENT!!!Thanks,Enrique Link to comment https://www.classiczcars.com/forums/topic/28036-air-filter-element-availability/#findComment-246775 Share on other sites More sharing options...
