Posted August 26, 200222 yr comment_14069 Hi, i want to sknow the number, model and mark of Spark Plugs for datsun 280zx 2+2 1980.thank you Link to comment https://www.classiczcars.com/forums/topic/2807-spark-plug/ Share on other sites More sharing options...
August 26, 200222 yr comment_14074 NGK BPR6ES Link to comment https://www.classiczcars.com/forums/topic/2807-spark-plug/#findComment-14074 Share on other sites More sharing options...
August 26, 200222 yr Author comment_14088 thank you, and in bosch line? Link to comment https://www.classiczcars.com/forums/topic/2807-spark-plug/#findComment-14088 Share on other sites More sharing options...
August 26, 200222 yr comment_14122 You can use NGK BPR6ES-11 as well different gap. Link to comment https://www.classiczcars.com/forums/topic/2807-spark-plug/#findComment-14122 Share on other sites More sharing options...
August 27, 200222 yr comment_14127 "and in bosch line?"That would be the VXC35dq-783, but make sure it is in the yellow box. If you use the one that comes in the black box, you will have troubles.NGKNGKNGKNGKNGKNGKYou will sleep now, and when I snap my fingers, you will not remember anything happening here, but you will motor to your local NAPA and purchase NGK BPR6ES. Six of 'em for your trusty Datto. It deserves them! Gap them to 40 but make sure your coil and wires are less than 30,000 miles old and your cap and rotor have less than 10,000. If you live in an area that gets in the 80's or 90's, you might try BPR7ES and if you are in the sunbelt (90-100+) you might try BPR8ES.NGKNGKNGKNGKNGK"snap"steve77 Link to comment https://www.classiczcars.com/forums/topic/2807-spark-plug/#findComment-14127 Share on other sites More sharing options...
August 27, 200222 yr comment_14129 Ok, my attorney is on the phone.....he says you are going to drive to your local KRAGEN and ask for the Bosch VXC35dq-783 in the yellow box and when they don't find them and laugh at you, you will sue me.(imadeitupsorry)steve77 Link to comment https://www.classiczcars.com/forums/topic/2807-spark-plug/#findComment-14129 Share on other sites More sharing options...
August 27, 200222 yr comment_14139 Zvoiture gets more interesting every day.... I think I like this guy... He might be as nutty as me.. maybe Link to comment https://www.classiczcars.com/forums/topic/2807-spark-plug/#findComment-14139 Share on other sites More sharing options...
August 27, 200222 yr comment_14143 But, what is he trying to say? :devious: Link to comment https://www.classiczcars.com/forums/topic/2807-spark-plug/#findComment-14143 Share on other sites More sharing options...
August 27, 200222 yr comment_14153 Quote That would be the VXC35dq-783, but make sure it is in the yellow box. If you use the one that comes in the black box, you will have troubles. Okay...The "yellow" means that you are talking about Bosch Super plugs which are Bosch's copper plugs. Bosch platinum comes in grey box and the Platinum 2's and 4's both come in black boxes. In my experience (none with Z's:( ) the Bosch platinum plugs are THE best. I can see you guys are just like the snowmobile guys that live and die by NGK's, which I can respect because when it's 15 below zero and you're 30 miles from the nearest town the last thing you want is your sled to die! I also run NGK's in my 600 Ninja, but have had good luck with Nipppondeno.Back to the point though... whats wrong with the platinums. The bosch plugs have a very small center electrode because they use 99% platinum cores which makes them leaps and bounds better than other platinum plugs...but if you are burning any oil or running very rich you can foul them very easy!Plug numbers would be:Bosch super"yellow box": 7501Bosch plat."grey box": 4217Nippondenso: 3067Nippondenso plat.: 3238Nate:cross-eye Link to comment https://www.classiczcars.com/forums/topic/2807-spark-plug/#findComment-14153 Share on other sites More sharing options...
August 27, 200222 yr comment_14159 I learned a hard lesson once, about 50 miles from nowhere. Keep German parts in German cars and keep Japanese parts in Japanese cars! Link to comment https://www.classiczcars.com/forums/topic/2807-spark-plug/#findComment-14159 Share on other sites More sharing options...
