Posted May 21, 200816 yr comment_248169 I hope to make this a Sticky (Mike!!) I want to Document every S30 style combo and Turn Signal Switch. I need every one to see what is already posted and add to this Thread if you don't see your style of switches. With any luck, anyone can pick up a switch out of a box of parts and be able to cross reference it here and know exactly what they have. I am now in possesion of over 80+ switches that I would like to start rebuilding for people and customers. Only problem is that there are so many styles that I am not totally sure of what is what. So PLEASE remove 4 screws from the steering column cover, take off the top and bottom covers and......... Take a picture of.... 1 of the top (looking from the roof down at the switches) 2 of the bottom (show the length of the T/S switch pigtail and the wires going into the T/S switch and the wiper switch. Try to show as much detail as possible that makes your switch different from the others listed. Make sure to STATE YOUR BUILD DATE!!! So everything can be properly documented. Thanks to all who participate. Dave. The pictures below are of my 8/70 and the combo switch and T/S switch wires are clearly visable as are the connectors. large 6-pin on the combo and small 6-pin connector on a short pigtail of the T/S. and a 6 wire T/S box. Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/ Share on other sites More sharing options...
May 21, 200816 yr Author comment_248237 This is for everyones benefit. You'll love this thread later, when you need it. Just takes 5 minutes and a camera. Anyone? Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/#findComment-248237 Share on other sites More sharing options...
May 21, 200816 yr comment_248243 Gotta wait until the car gets back from the paint shop, Dave. You know I won't let you down... Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/#findComment-248243 Share on other sites More sharing options...
May 21, 200816 yr comment_248245 Dave, I have a NOS combo switch that matches your 8/70 one. I won't double up on the pic's but here's one of the Part#. Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/#findComment-248245 Share on other sites More sharing options...
May 21, 200816 yr comment_248246 I don't have a top view (yet), but here is my 01/71. Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/#findComment-248246 Share on other sites More sharing options...
May 21, 200816 yr Author comment_248268 That's perfect Mat, is there a double black wire (1 small and 1 large) on the top of the headlight switch? And does the small black wire from the wiper switch go to the top of the headlight switch?Thanks and keep 'em coming guys, the more, the marrier.Dave. Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/#findComment-248268 Share on other sites More sharing options...
May 22, 200816 yr Author comment_248397 Here's another .... 2/73 240Z 3 position wiper and usual everything else, long pigtail on Turn signal switch. Also, I believe the combo switch sits on an upper angle (due to the 3 position wiper switch) as compared to the earlier 240Z switches that sit in the center of the metal chassis. Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/#findComment-248397 Share on other sites More sharing options...
May 23, 200816 yr Author comment_248445 Come on people. Take 5 minutes to go take a picture of your switches. I really need a picture of an 8/71 and a top view of the 1/71, MATT. But I still need some more input from every one who can add to this.Let's fill this thing up. If you don't see your switches on here, ADD them.Thanks,Dave Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/#findComment-248445 Share on other sites More sharing options...
May 23, 200816 yr comment_248470 Dave,I will take pictures of my 1/72 on Saturday, when my wife will bring the camera back from work. I will definitely buy one of your reconditioned units for my car. Thanks!Bill Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/#findComment-248470 Share on other sites More sharing options...
May 23, 200816 yr comment_248515 hi dave these are pics of JAN 1971 HS30 00501 RHD as far as i know the first 1971 RHD produced, HLS30 00501 LHD was sold in Canada and ended in the wreckers anyhow enough history hers the pics Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/#findComment-248515 Share on other sites More sharing options...
May 23, 200816 yr Author comment_248535 and to add to the 2/73' pics, here are a finished pair that I'm doing for "ZUP" And I really need pics and dates of what ever Z used the 3 wire Turn Signal switch with a 3 wire connector. Dave. Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/#findComment-248535 Share on other sites More sharing options...
May 24, 200816 yr comment_248712 Zs-ondabrain said: Make sure to STATE YOUR BUILD DATE!!! So everything can be properly documented.Dave - Between the ones I sent you and the refurbished one you sent back, I can't be for sure on the build date(s) of any specific car(s) they came out of. However, they were all from 280Z's. Sorry I couldn't be more help. Taking a picture of what I (re)installed in the car is pointless, as I'm not sure the date of the original donor. But from the picture, it doesn't look like I was the only one who donated to your "illness"......Wayne Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/#findComment-248712 Share on other sites More sharing options...
