October 13, 200915 yr comment_297384 Dave, I appreciate your message, and will email you soon. Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/?&page=5#findComment-297384 Share on other sites More sharing options...
October 14, 200915 yr comment_297456 Thanks for the tip Dave. Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/?&page=5#findComment-297456 Share on other sites More sharing options...
October 25, 200915 yr comment_298414 Zs-ondabrain: What is really needed are schematics of the Turn Signal Left hand stalk and the Right Hand Stalk combination of switches for those completely rewiring a 240Z. With your knowledge and ability to rebuild these switch assemblies it should not be too difficult to come up with schematics of same. Would like to hear feedback from you regarding this matter. Please advise. Thanks. Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/?&page=5#findComment-298414 Share on other sites More sharing options...
October 25, 200915 yr Author comment_298424 I'll see what I can do..... this should get ya started, I'll try and work on more variences later, when I have more time. Dave Edited October 25, 200915 yr by Zs-ondabrain Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/?&page=5#findComment-298424 Share on other sites More sharing options...
February 21, 201015 yr comment_310190 I do believe this is a 03/72. HLS30-71960 I got a little trigger happy w/ the camera as I was taking it apart. Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/?&page=5#findComment-310190 Share on other sites More sharing options...
February 21, 201015 yr comment_310191 Here's the last three photos that did not fit in the last post. Hope this helps. Edited February 21, 201015 yr by fiveleaf Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/?&page=5#findComment-310191 Share on other sites More sharing options...
February 21, 201015 yr Author comment_310209 Yup, you definately got a short in the left turn signal. Concentrate on the left turn lights.They are green/red in the front and rear, at the hazard switch and at the light in the tach. You should be able to trace it easily that way. It's ground out somewhere.By the way, The average price of a 240Z Starter is $40. Just go buy one. Even a Pull-A-Part starter out of a 280ZX (gear reduction) is about $10. Mine was $10 and that was over 3 years ago.Dave Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/?&page=5#findComment-310209 Share on other sites More sharing options...
May 7, 201014 yr comment_318696 do you buy chance have any pics of a 260z headlight switch and connector? ive had the car for a few years and its time to start fixing it up. the problem im having is the P.O. or someone before him cut the plugs off both switches, i got the turn switch figured out since the wires all matched in color, but none of the three headlight switches i have match the car side wires, well, most, the dash lights is about it. i have a FSM but it seems all my switches are for a different car. my build date is 7/74. thanks Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/?&page=5#findComment-318696 Share on other sites More sharing options...
May 7, 201014 yr comment_318715 Sam,Dave will probably come through with pictures before I can. I have a 260Z combo switch sitting in my garage. Unfortunately, I'll be a few hundred miles from my garage for the next couple of weeks. (Does anybody know when it's supposed to get warm in Canada?)One bit of good news is that RockAuto has a replacement switch that looks like NOS for only $200. I put one in my 260Z. Also, VintageConnections has 9 wire connectors that will work with the headlight switch in case you want to replace the connectors. Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/?&page=5#findComment-318715 Share on other sites More sharing options...
May 7, 201014 yr comment_318716 Zs-ondabrain said: Here's another ....2/73 240Z3 position wiper and usual everything else, long pigtail on Turn signal switch.Also, I believe the combo switch sits on an upper angle (due to the 3 position wiper switch) as compared to the earlier 240Z switches that sit in the center of the metal chassis.My car is a 2/73 so unless you want pics from me I'll stay out of this. Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/?&page=5#findComment-318716 Share on other sites More sharing options...
May 7, 201014 yr Author comment_318717 Damnit Sam, I was JUST in Auburn Yesterday. Had to go to "Carbs Unlimited" off 22nd and Auburn way? I could have brought you a switch. I have a couple (dozen? maybe?)I'll try and take a picture for you tomorrow. But check this thread for and late 73' switches, they are the SAME.Dave Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/?&page=5#findComment-318717 Share on other sites More sharing options...
May 7, 201014 yr comment_318777 oh man, that wouldve been awsome! but i guess pics will work, thanks man Link to comment https://www.classiczcars.com/forums/topic/28173-i-need-everyones-input-on-this-one-combo-and-ts-switches/?&page=5#findComment-318777 Share on other sites More sharing options...
