I need everyones input on this one (Combo and T/S switches)
Zs-ondabrain
9 hours ago, SteveJ said:
Here is the 9-pin connector: https://www.vintageconnections.com/products/2-8mm-connectors?variant=46131774095681
The best thing to do is to change out the lights on the circuit to LEDs and derate the fuse to 10A or less. I really don't think that connector was designed for over 10A.
Thank you, Steve - those are indeed the ones! Of course, that site doesn't actually tell you the make of the terminals. I don't need the housings. 😄
It's probably safer the way I have it now, through a larger surface area bullet terminal.
Edited by HusseinHolland
With as curious and ingenious as you are, you didn't explore their site? LOL https://www.vintageconnections.com/products/2-8mm-spade-terminals
  • Haha 2
On 4/17/2019 at 11:07 PM, jalexquijano said:
What about the size and type of screw that goes through the steering wheel shroud and into the turn signal switch
Probably no use to the OP - these are the 3 types I found on my 280Z.
4 shroud screws, approx 15mm L
1 M3 x.5 12mm L pan head machine screw into combi switch housing
1 M4 10mm L machine screw into ignition switch housing (didn't bother measuring pitch, it's the same as all the other M4 machine screws on the dash).
