That looks very much like the fan on the oil cooler on a 280ZX turbo with automatic transmission. I tried the partnumber and a few variations due to clarity-no good numbers.
Will
Actually, all the numbers are good except the first one, the fan itself and the first 'switch thermo number. None of those are available, however.
215590-N4200 Assy motor fan*
08360-81626 Screw machine
21503-N4206 Hose radiator A
21504-N4206 Hose radiator B
21595-M0205 Switch thermo*
21595-M0206 Switch thermo (alternate)
21596-N4205 Adapter hose
05412-1600P Gasket B
08723-13800 Clamp hose
*no longer good numbers.
  • 3 weeks later...
I have an electric fan sitting in my garage that came out of a 81_280zx turbo with the automatic and the fan does not have that big schroud around it and the motor is quite a bit smaller then the one in the drawing. I can take a pictue of it if you would like me to.
it was mounted directly to engine side of the radiator. Oh and I do have one of the FI cooling fansaround also.
Seeing how I will be switching my radiator to the 81 radiator this weekend due to the fact that my 76' rad. blew a hole in it this week, I may get the urge to use the electric fan instead of the belt driven one.
