Posted May 22, 200816 yr comment_248333 Hey guys, new to the forum, need some help.This problem just developed last night, suddenly, and out of the blue.When I am idling the car will die. When it does this I get a spike on my tach from the 800 idle to 3k. This leads me to believe its gotta be something elictrical. I don't even know where to start. If anyone has ideas please post them. I'm not very knowledgable so try to give some instructions as to how to do things or explain what the part in question I should be checking looks like/where it is. Thanks. Link to comment https://www.classiczcars.com/forums/topic/28193-car-dies-at-idle/ Share on other sites More sharing options...
May 22, 200816 yr comment_248365 Please post the model year of the car. Link to comment https://www.classiczcars.com/forums/topic/28193-car-dies-at-idle/#findComment-248365 Share on other sites More sharing options...
May 22, 200816 yr Author comment_248386 Oops sorry, its a 77 280z Link to comment https://www.classiczcars.com/forums/topic/28193-car-dies-at-idle/#findComment-248386 Share on other sites More sharing options...
May 23, 200816 yr comment_248463 Check your AFM. It's on the left side, I believe over by the distributer on the 280z. Check a factory service manual or google one so you know how it looks like. Make sure it's connected and that the connections are clean. I'm having similar problems and they're rooted there. Link to comment https://www.classiczcars.com/forums/topic/28193-car-dies-at-idle/#findComment-248463 Share on other sites More sharing options...
May 23, 200816 yr comment_248464 I'd leave the AFM alone for now. It wouldn't cause a tach spike. Usually, that has to do with the alternator/regulator and things in that loop/circuit. Link to comment https://www.classiczcars.com/forums/topic/28193-car-dies-at-idle/#findComment-248464 Share on other sites More sharing options...
May 23, 200816 yr comment_248465 Well it sounds exactly like what was happening to my car, by cleaning out the connection and wiggling it into proper place it really helped. Link to comment https://www.classiczcars.com/forums/topic/28193-car-dies-at-idle/#findComment-248465 Share on other sites More sharing options...
May 23, 200816 yr comment_248466 Cleaning the AFM connection can't hurt. I actually meant not to attempt to adjust it. I've seen many posts where people have opened up the AFM in attempt to solve a problem that really had nothing to do with it and ended up creating new issues on top of the existing problem. Link to comment https://www.classiczcars.com/forums/topic/28193-car-dies-at-idle/#findComment-248466 Share on other sites More sharing options...
May 23, 200816 yr comment_248469 Well I didn't recommend opening it up, I just moved it around a little until it was in it's proper place. Mine's kind of hanging down under the intake manifold being held up by a tied up green wire, swap ftl. It's pretty fast though Link to comment https://www.classiczcars.com/forums/topic/28193-car-dies-at-idle/#findComment-248469 Share on other sites More sharing options...
May 23, 200816 yr Author comment_248507 What is the AFM? Im kinda a newb to the Z only had it for about a week, but always wanted one. Link to comment https://www.classiczcars.com/forums/topic/28193-car-dies-at-idle/#findComment-248507 Share on other sites More sharing options...
May 23, 200816 yr comment_248509 Air Flow Meter. Link to comment https://www.classiczcars.com/forums/topic/28193-car-dies-at-idle/#findComment-248509 Share on other sites More sharing options...
