I've got a '78 280z (4 speed), and I'm afraid that the transmission is on its way out. I was considering replacing it with a 5 speed, but I've heard mixed things on the early and later 5 speeds. What's the difference?
-Ben
Are there any differences between the various 5 speeds as far as how they mount into the car and where the shifter sits? I've heard that some require cutting on a 240Z and others don't?
Greg
Greg
That's not a difference with the transmission, but with the car. Early 240Zs have a smaller opening in the transmission tunnel than do later Zs.
Greg,
The swap will not require any cutting into the '72 and '73 240s. Only the series one cars '70 and early '71 need the opening expanded. I thought it was because the shifter on the tranny sat farther back. The 4 speeds in our cars match the 5 speeds.
  • 2 years later...
Does anyone on here know how to tell if you have a 5 speed out of a 77-79, 80, or 81? I have one and I'm not sure what year it came out of? Are there any numbers that will help me? Thanx
Bryce
I have a 11/70 build that I fitted with a late 5 speed and then a KA conversion. It had a type-A 5 speed when I acquired the car. The tunnel opening was never modified.
