I need help identifying and locating the relay that controls the electric fuel pump on a 73 240Z. The original owner of the Z informed me that it quit working before he stored the car. I have traced the power lead in the electrical schematic from the battery to the fuse panel and I have found the green wire lead for the fuel pump that has an inline fuse. The fuse by the way is good. However I lost it again under the dash headed over to the group of relays that are located on the passenger side outside wall, but these old eyes can not find the relay nor the wire leading to it.
I need this information to correct the vapor lock problem that the electrical pump was originally installed to correct.
Could someone please provide the correct part number for the relay and its true location.
Thank
  • 3 weeks later...
there is a member here in the club . Go to the members list and find escanlon and send him a e-mail and I am pritty sure he can help. Incidently a good source for a pump is one from a RX 7 that is NOT fuelinjected but carberated . About $15.00 at t he local bone yard. It will supply low pressure and it is quiet just like the origional one .
