Email logins are now active ×
Emissions
bstevenguy
Hey guys hoping someone can help me out here.
I live in Las Vegas, and recently bought myself a 77 280z. This is my toy, that I am restoring. However, I'd still like to have it registered, as it will be a work in progress. I went to get it smogged, and it failed miserably.
CO ~10% 2.5% is max
HC ~1200 500 is max
Pretty bad..
I think its because its running extremely rich. There is definately a gas smell coming from the exhaust. Also the gas mileage definately seems really bad, about as bad as my 90 mustang gt.
Anyone have any idea what I could do to fix it? I checked the EGR valve and I think its faulty, so I'll be replacing that. Could this be the sole cause? Or do I need to have the AFM adjusted? What else could I check/do at home as I dont want to spend the horrendous charges of a shop?
Thanks.
The EGR valve won't be the sole cause of those bad readings. Bad mileage and fuel smell sound like you have EFI component problems. I wouldn't touch the AFM adjustment without something to read the results which I do have but most people don't at home. You need to go through the component and functional systems tests as outlined in the FSM.
Engine runs fine.
When it first starts, while cold, it does emit a small amount of visible vapor, however once warmed up its not visible. While cold if you were to stick your hand near the tail pipe you will get little black dots, I'm assuming thats carbon.
I havnt checked the spark plugs, but wont have a chance to work on her til friday evening.
  • Who's Online   1 Member, 0 Anonymous, 549 Guests (See full list)
