Ho ho... my L28 is at last in my 240Z, together with a nice 5 speed!
The engine is running sort of OK as far as I can tell... I have no shaft yet so testing the engine with really unsupportive neighbor is difficult. It's smouth and not leaking.
My question: is it mandatory to use the second dowel on a new timing chain kit with a fast road cam? I have read so and would appreciate if I could cut this corner :squareeye But I guess the 4° of timing are going to be missed power wise, no?
My spec are:
F54
Flat tops
1 mm skimed head
1 mm shims
Fast road kent camshaft
280ZX dist
6/2/1 and 1/2 exhaust
You need to time or "degree" the cam. It's not as simple as advancing or retarding x degrees. When you get a new cam it will come with a card that shows when the valve is supposed to open to get the intended performance from the cam. You can use that information and follow the procedure here to get the most from it:
http://forums.hybridz.org/showthread.php?t=111523
