June 1, 200816 yr comment_249481 no way Sblake made a mistake? jk man.you got the ratings and thicknesses backwards. 1.25 is black .50 is green Link to comment https://www.classiczcars.com/forums/topic/28296-no-electrical-power/?&page=2#findComment-249481 Share on other sites More sharing options...
June 1, 200816 yr comment_249483 no way Sblake made a mistake? jk man.you got the ratings and thicknesses backwards. 1.25 is black .50 is green It's just a typo. When I realized it, it was too late to edit. Link to comment https://www.classiczcars.com/forums/topic/28296-no-electrical-power/?&page=2#findComment-249483 Share on other sites More sharing options...
June 2, 200816 yr Author comment_249552 Well, got the mounting plate made for the fuse blocks and put it all together. I posted photos in my gallery.Thanks again to everyone for the support and guidance in addressing this electrical issue. I am very pleased with the results. Best regards,PSB Link to comment https://www.classiczcars.com/forums/topic/28296-no-electrical-power/?&page=2#findComment-249552 Share on other sites More sharing options...
June 4, 200816 yr Author comment_249764 All looks good, runs well, but volt gauge is just below 16 when accelerating. At idle, hangs around 13.Alternator is new (maybe 10 hours on it), so do I need a voltage regulator?Thoughts? Link to comment https://www.classiczcars.com/forums/topic/28296-no-electrical-power/?&page=2#findComment-249764 Share on other sites More sharing options...
June 4, 200816 yr comment_249790 All looks good, runs well, but volt gauge is just below 16 when accelerating. At idle, hangs around 13.Alternator is new (maybe 10 hours on it), so do I need a voltage regulator?Thoughts?That's pretty much what my 78 reads and has read ever since I've owned it. The factory gauges aren't too accurate, at least mine isn't. When tested with a hand held meter, it shows 14.1-14.7 which is normal. Link to comment https://www.classiczcars.com/forums/topic/28296-no-electrical-power/?&page=2#findComment-249790 Share on other sites More sharing options...
June 5, 200816 yr Author comment_249795 Thanks, I feel much better now... Link to comment https://www.classiczcars.com/forums/topic/28296-no-electrical-power/?&page=2#findComment-249795 Share on other sites More sharing options...
