73'Z Posted July 22, 2008 Share #13 Posted July 22, 2008 So i understand that 71' 240z bumpers will not fit a 73 correct? Link to comment Share on other sites More sharing options...
EScanlon Posted July 22, 2008 Share #14 Posted July 22, 2008 So i understand that 71' 240z bumpers will not fit a 73 correct?They'll fit. This thread is about the Bumper Guards, as labeled within this thread, or Overriders per Nissan's part CD, not to be confused with the tubular bumper Guards offered as an aftermarket accessory (that is commonly referred to as an overrider) which in the front mounted up above the overriders (guards in this thread), which are sometimes called "bumperettes". (The rear overrider bar mounted to the bumper and not the "guards".)But to fit the 71 bumpers you'll probably have to change the mounts (front) and do some modification to the rear bumper or mounts depending if you have the shock absorber mount there. There is lots more info if you do a search for the "early style bumper" or Series I.FWIWE Link to comment Share on other sites More sharing options...
cunniwj Posted July 22, 2008 Share #15 Posted July 22, 2008 I know this is spinning this thread a bit but does anyone know where to get the black rubber bumper guard covers for the rear of a 72. Mine are cracked and I have not been able to find them on Blackdragon or MSA. Thanks Bill Link to comment Share on other sites More sharing options...
