Posted June 3, 200816 yr comment_249660 the seat belt timer does that also control the power windows?? the part I pulled out that is what according to the repair manual is thepower window circuit breaker , BuyNissanParts.com is saying is the seat belt timer, which isn't avilable any more I'm getting extremely discouraged over this car! I need some help please someone with some knowhow call me 0419043901528 Ohio (take out all three 0s) Thank you. Link to comment https://www.classiczcars.com/forums/topic/28318-power-windowsseat-belt-timer/ Share on other sites More sharing options...
June 3, 200816 yr comment_249671 How many connections does it have? The power window circuit breaker has 2 and the seat belt warning timer has 3. Link to comment https://www.classiczcars.com/forums/topic/28318-power-windowsseat-belt-timer/#findComment-249671 Share on other sites More sharing options...
June 3, 200816 yr Author comment_249680 sblake01 said: How many connections does it have? The power window circuit breaker has 2 and the seat belt warning timer has 3.it has 3 , is the power windows circuit breaker near the seat belt circuit breaker Link to comment https://www.classiczcars.com/forums/topic/28318-power-windowsseat-belt-timer/#findComment-249680 Share on other sites More sharing options...
June 3, 200816 yr comment_249681 I tried to call you-and edited your number to keep it bot safe. Here is the part drawing for what you are looking for. Mine had rubber boots over the connections-but looked the same. Just hit up your local autoparts store-what you get may not have a mounting hole, but it will still work like a champ! No need for OEM parts here! Link to comment https://www.classiczcars.com/forums/topic/28318-power-windowsseat-belt-timer/#findComment-249681 Share on other sites More sharing options...
June 3, 200816 yr comment_249684 If it has three connectors, he's is looking for the seat belt warning timer. Link to comment https://www.classiczcars.com/forums/topic/28318-power-windowsseat-belt-timer/#findComment-249684 Share on other sites More sharing options...
