Posted June 6, 200816 yr comment_249955 As I continue cleaning and reassembling my car, I've come across a question. The black metal filler panel (in front of the dash pad at the base of the windshield) is retained by five sheet metal screws. The finish on the screw heads of mine have me wondering what is correct. Mine appear to be chrome screws that have had their heads painted black. The black paint is chipping off all of them, leaving a mottled finish.I could see them being either black or chrome, and if they were all five the same and in good condition (with either finish) I would never have given it a second thought. But as they are, I need to figure out which finish is correct. Right now I'm leaning toward chrome, and that the original owner painted them black at some point in the past. Any confirmations for either finish from 240Z owners? Link to comment https://www.classiczcars.com/forums/topic/28345-240z-dash-filler-screws-chrome-or-black/ Share on other sites More sharing options...
June 6, 200816 yr comment_249956 Arne, On my '73 they are satin black. To my knowledge they are original (75,000 miles). FWIW I think that little shiny screws would be distracting when driving. Mike Link to comment https://www.classiczcars.com/forums/topic/28345-240z-dash-filler-screws-chrome-or-black/#findComment-249956 Share on other sites More sharing options...
June 6, 200816 yr comment_249957 Henry Ford knew this answer-any color you want as long as it's blackWill Link to comment https://www.classiczcars.com/forums/topic/28345-240z-dash-filler-screws-chrome-or-black/#findComment-249957 Share on other sites More sharing options...
June 6, 200816 yr Author comment_249959 I agree that black would be better, less distracting while driving. So if that's what others have as well, I'll repaint this set. Thanks! Link to comment https://www.classiczcars.com/forums/topic/28345-240z-dash-filler-screws-chrome-or-black/#findComment-249959 Share on other sites More sharing options...
June 6, 200816 yr comment_249960 I just had a look at mine from a 10/70 which are still tagged in a baggie. They are the standard flat black oxide finish. I tried to remove some of the finish to reveal what you describe, but couldn't. Link to comment https://www.classiczcars.com/forums/topic/28345-240z-dash-filler-screws-chrome-or-black/#findComment-249960 Share on other sites More sharing options...
June 6, 200816 yr comment_249969 And mine are black as well Arne, they've never been removed. Link to comment https://www.classiczcars.com/forums/topic/28345-240z-dash-filler-screws-chrome-or-black/#findComment-249969 Share on other sites More sharing options...
June 6, 200816 yr comment_249970 Mine ('73) are black as well. If I remember correctly, they are completely black, and not painted chrome/whatever. Every time I've taken that panel off (3 non-fitting full-face dash covers, 1 fitting half-dash cover, and before and after my repainting) I've thought to myself "I better not loose one of these down the air ducts into the fan etc., because I bet I'll never find a correct replacement." Link to comment https://www.classiczcars.com/forums/topic/28345-240z-dash-filler-screws-chrome-or-black/#findComment-249970 Share on other sites More sharing options...
June 6, 200816 yr comment_249972 AFAICT, those screws are like 1/2", #10 wood screws, but with a raised phillips head. They should not be too difficult to find.Installing them andgetting the dask cap underneath with out chipping the paint is another matter tho. :surprised Link to comment https://www.classiczcars.com/forums/topic/28345-240z-dash-filler-screws-chrome-or-black/#findComment-249972 Share on other sites More sharing options...
June 6, 200816 yr comment_249975 AFAICT, those screws are like 1/2", #10 wood screws, but with a raised phillips head. They should not be too difficult to find....snip....Wood screws? So besides rust, we now have to worry about termites! :tapemouth Link to comment https://www.classiczcars.com/forums/topic/28345-240z-dash-filler-screws-chrome-or-black/#findComment-249975 Share on other sites More sharing options...
June 6, 200816 yr comment_249976 <-- definitely not a carpenter Link to comment https://www.classiczcars.com/forums/topic/28345-240z-dash-filler-screws-chrome-or-black/#findComment-249976 Share on other sites More sharing options...
June 6, 200816 yr comment_249979 I just had a look at mine from a 10/70 which are still tagged in a baggie. They are the standard flat black oxide finish. I tried to remove some of the finish to reveal what you describe, but couldn't.I agree with Ron, they have the black oxide finish, just like the four oval head, countersunk machine screws that fasten the heater control panel to the dash. Just as a point of interest that I have noticed, the four screws that fasten the front edge of the cowl panel are, also, black oxide oval phillips head self tapping screws. I often see these replaced on cars by chrome or clear zinc screws that have heads that are also too small.Dan Link to comment https://www.classiczcars.com/forums/topic/28345-240z-dash-filler-screws-chrome-or-black/#findComment-249979 Share on other sites More sharing options...
June 6, 200816 yr comment_249980 Wood screws, sheet-metal screws; same thing to me. It's basically a #8 or #10 flathead phillips screw. Link to comment https://www.classiczcars.com/forums/topic/28345-240z-dash-filler-screws-chrome-or-black/#findComment-249980 Share on other sites More sharing options...
