Broken Mounting Insulator
74260ZMan
So i was replacing the struts and bushings on my late 260Z and i had put the control arms back in and called it a night, well today i walk out into the garage and my left control arm is touching the ground, a quick inspection shows my mounting insulator has separated. My question is can i glue or epoxy the insulator back together. (im a student and dont have a job, and the only replacement i can find is $186) I dont think that it would be a problem since the weight of the car keeps the two pieces together anyways. Your ideas are appreciated
Well, isn't that pooey:angry::angry:
Unfortunately, I don't think a back yard fix is possible.
That item is originally a vulcanised rubber to metal part.
Don't try to use the damaged strut top even if you do manage to glue it with anything:finger::finger:
No option in my opinion, but to get a replacement:rolleyes:
Oh, you might need to seriously think about doing the other side too.
I know you don't want to hear that but...
Well when I looked up replacements they have two insulators for the rear struts the first are for 70-7/74 and the other ones are from 8/74-78. My Z has a build date of 12/74 so I don't think that the early ones would fit. What do you guys think?
