Hey, my 240Z emblem on the hatch isn't connected on one side, the otehr side is good, but it will kinda rotate to a down position if u bump it or something like that...so i was wonderin how do i get it to stick properly..And does anyone know how much a body kit type thing will cost for a 240Z just curious not really thinking about puttin one on...well kinda anyways...thanks
https://www.classiczcars.com/forums/topic/2839-emblems/
Right on Ed, apart from double sided tape, the other alternative is a poly urethane not like the one used for your windscreen that stays soft but one used for sealing panels it will stay rubbery but will set and keep the sucker on for good.
https://www.classiczcars.com/forums/topic/2839-emblems/#findComment-14376
On the subject of the double sided sticky tape, they are referring to the one you get at the Auto Parts Store. It is a rubber based just about 1/16" thick and has a sticky film on it that will NOT bleed or discolor your paint. There are other double sticky tapes out there that are spongier and / or have adhesive that will not hold or will discolor paint.
Personally I recommend the 3M brand.
Whatever you do, DO NOT EPOXY or GLUE it in place, as my IPO* did. You will be guaranteed to peel or damage the paint if you should have to remove it for ANY reason.
(* IPO = Idiot Prior Owner)
https://www.classiczcars.com/forums/topic/2839-emblems/#findComment-14399
The emblems are not always available new.
In my case they were removed for painting (by the previous owner), and the mounting tabs broke off. The emblems were in good condition otherwise. I just a bit of Silicon Glue on the backs and they have stayed on with no probelms.
https://www.classiczcars.com/forums/topic/2839-emblems/#findComment-14754
I have to agree with the previous post. Clear silicone is ideal. It will not damage the paint and you can 'adjust' the badge for a while after you stick it on to get the angle perfect. When you're happy, you can temporarily tape the badge while the silicone sets. To remove the badge in the future, simply run a piece of fishing line behind the badge and then rub off the remaiing silicone from the paintwork. I have used this method for years and never lost a badge.
I can't imagine that double sided tape would allow the badges to sit nice and close to the paintwork..?
https://www.classiczcars.com/forums/topic/2839-emblems/#findComment-14785
The tape is only about 1/16" or less thick.
If you trim it close to the emblem, it would be very difficult to discern.
Many manufacturers are using it to hold various emblems in place in lieu of a gasket.
https://www.classiczcars.com/forums/topic/2839-emblems/#findComment-14914
  Quote
I've heard clear silicon is slightly acidic an shouldn't be used on cars? anyone else heard this. Windscreen fitters might know, as they always use the black sealant. I used heaps of silicon on my 240z ages ago, but dont own the car anymore. I agree its great for sticking on badges, and stopping leaks, but if its gonna eat into your car I wouldnt be using it in the future.
https://www.classiczcars.com/forums/topic/2839-emblems/#findComment-14931
