Posted June 11, 200816 yr comment_250454 I've been wanting to do something different as far as attacking the flimsy interior plastic in the early Z. I could buy some new and spend 500$ for a complete new plastic interior or try something different and maybe better to some. I finally finished off one panel today. Basically I just fiberglassed the back side of all my panels to strenghthen them plus repair any cracks or broken pieces. Then I plan to vinyl cover the panels. I thought the vinyl would match the rest of the interior plus provide some noise suppression and the panels would be much stronger and last my life time. I picked out the easiest panel today to cover with the vinyl(which i found a perfect match at Joanne fabrics). I learned today that i will have to getter better tools for the job. 3m is great stuff but i need a better way to spray the panel. The aresol can sprays to wide which makes for sloppy work.I also cut the material too close to the panel in several spots which i tried to show in the pic, but I think I know how to remedy that. I also odered the specific glue to spray with my gun. So far i have $ invested: 30$ vinyl 60$ glue and spray gun( that's a gallon of glue) 40$ fiberglass resin and hardener 20$ fiberglass cloth As you can see i don't have a lot of money in it, but I didn't do this just to save money, I did this for the look also. I am not using the original vinyl, i will be carpeting everything else in the car. So there shouldn't be vinyl overload.I actually enjoy this kind of work too. Of course, once i get to doing the more complicated panels i might not like it as much Link to comment https://www.classiczcars.com/forums/topic/28393-my-interior-plastic-repair-and-resto/ Share on other sites More sharing options...
June 11, 200816 yr comment_250458 Looks fantastic. I might have to go the same route soon, but I'm still working on the mechanics of the car. Wiring and interior are next. Link to comment https://www.classiczcars.com/forums/topic/28393-my-interior-plastic-repair-and-resto/#findComment-250458 Share on other sites More sharing options...
June 11, 200816 yr comment_250459 That will work well and add quite a bit of strength. The only thing to watch out for is fitment interference. I have done this on small problem pieces that had started to crack and it worked well. Doing all the panels will be quite a project, but worthwhile. Good Luck! Link to comment https://www.classiczcars.com/forums/topic/28393-my-interior-plastic-repair-and-resto/#findComment-250459 Share on other sites More sharing options...
June 11, 200816 yr comment_250461 Very nice work, i also might have to go this route, the fiberglass strenthening was a smart idea those panels are just so brittle. Link to comment https://www.classiczcars.com/forums/topic/28393-my-interior-plastic-repair-and-resto/#findComment-250461 Share on other sites More sharing options...
June 11, 200816 yr comment_250467 wow looks great.You might want to check out this gluehttp://www.glueplace.com/1081-spray-trim-adhe.htmlThis is the best price I've foundThis stuff is really good. The spray pattern is very narrow and controllable.Derek Link to comment https://www.classiczcars.com/forums/topic/28393-my-interior-plastic-repair-and-resto/#findComment-250467 Share on other sites More sharing options...
June 11, 200816 yr comment_250470 Provided one has the time, skills, and resources ($).....your method seems to be an excellent one! Good old craftsmanship and clever thinking are hard to beat.Tom Link to comment https://www.classiczcars.com/forums/topic/28393-my-interior-plastic-repair-and-resto/#findComment-250470 Share on other sites More sharing options...
June 11, 200816 yr Author comment_250475 thanks guys! Like i said , that is the easy panel, the ones with the complex curves are going to be a challenge.Derek, the spray can glue isn't really good at this level of covering. You need a more accurate spray from an actuall gun made to shoot glue. It's only 30$ so i sprang for it. Aresol sprays to wide an erratic and causes a big mess if your not careful. I'll post as i go along here. I'm waiting on my gun and glue before I move on to bigger and badder things. I wish i was good enough to cover a dash:pThis is a cool site for interior stuffhttp://www.yourautotrim.com/ Link to comment https://www.classiczcars.com/forums/topic/28393-my-interior-plastic-repair-and-resto/#findComment-250475 Share on other sites More sharing options...
