Posted June 13, 200816 yr comment_250670 I'll leave my proper introduction to when I sell this car and finally get my 240 on the road. Until then, I'd appreciate some help. I just gave my 280Z a tune up, and surprise surprise, no more starting. At first I put the wires in the wrong order, so it misfired. Realizing this, I switched back to the proper order, and at this point all it does is crank to some ridiculous extent. It has fuel, air, and spark. My current guess is that the replacement distributor cap is the culprit, since the original looked like this: and the replacement looks like this: I'd think that maybe timing is now off by some 15 or so degrees because of the new cap (which is the only replacement I've been able to find) and is the source of my dilemma. I'm dying here guys. It's been an entire week without a car, and I can't put my recently purchased 240Z on the road until I sell this car. I used up some emergency funds because I was sure that I'd sell the 280Z in a few days, but then this happened . Link to comment https://www.classiczcars.com/forums/topic/28416-car-wont-start-after-tune-up/ Share on other sites More sharing options...
June 13, 200816 yr comment_250683 Is that replacement cap made for 280Z or? Else try to find on Ebay or contact somebody here for the original one... Link to comment https://www.classiczcars.com/forums/topic/28416-car-wont-start-after-tune-up/#findComment-250683 Share on other sites More sharing options...
June 13, 200816 yr comment_250685 So have you re-installed the original cap to test this? Link to comment https://www.classiczcars.com/forums/topic/28416-car-wont-start-after-tune-up/#findComment-250685 Share on other sites More sharing options...
June 13, 200816 yr Author comment_250689 My dumb arse threw all the old stuff away Link to comment https://www.classiczcars.com/forums/topic/28416-car-wont-start-after-tune-up/#findComment-250689 Share on other sites More sharing options...
June 13, 200816 yr comment_250695 Then my first step would be to find a different cap to see if that makes a difference. Also verify that you have it properlyattached to the distributor. You haven't loosened th edistributor mount during this process, have you? Link to comment https://www.classiczcars.com/forums/topic/28416-car-wont-start-after-tune-up/#findComment-250695 Share on other sites More sharing options...
June 13, 200816 yr Author comment_250710 No sir. Went hunting for a different cap, but couldn't find one. The original one has the plug in for the 1st wire "closest to the radiator." This one has two ports (going down, 4 and then 1) parallel to each other. Link to comment https://www.classiczcars.com/forums/topic/28416-car-wont-start-after-tune-up/#findComment-250710 Share on other sites More sharing options...
June 13, 200816 yr comment_250711 I don't understand those two pics. The top one looks like it's from an EFI L6(Intake hose along the bottom?) and the bottom pic is from a carbed L6....different upper rad hoses....am I hallucinating?How do you know you have spark at the plugs? Link to comment https://www.classiczcars.com/forums/topic/28416-car-wont-start-after-tune-up/#findComment-250711 Share on other sites More sharing options...
June 13, 200816 yr comment_250712 There are two caps. A taller one and a shorter one and rotors to go with them. You can use either set as long as they match. You'll know if you put the short cap over the tall rotor because it won't go all the way on but if you put the tall cap over the short rotor, it will fit but the rotor won't be close enough to reach the cap's contacts. I found this out a few years ago because my Z has the shorter combo and my 810 has the taller combo. Link to comment https://www.classiczcars.com/forums/topic/28416-car-wont-start-after-tune-up/#findComment-250712 Share on other sites More sharing options...
June 13, 200816 yr comment_250723 I don't understand those two pics. The top one looks like it's from an EFI L6(Intake hose along the bottom?) and the bottom pic is from a carbed L6....different upper rad hoses....am I hallucinating?How do you know you have spark at the plugs?I thought I had seen those pics before...http://classiczcars.com/forums/showthread.php?threadid=30868How about showing us your own situation with pics of your car's distributor/ignition components, so I/we can see and understand better what's going on? Link to comment https://www.classiczcars.com/forums/topic/28416-car-wont-start-after-tune-up/#findComment-250723 Share on other sites More sharing options...
June 14, 200816 yr comment_250735 The second picture is from a 1972 l24.... mine to be precise. Link to comment https://www.classiczcars.com/forums/topic/28416-car-wont-start-after-tune-up/#findComment-250735 Share on other sites More sharing options...
June 14, 200816 yr Author comment_250743 I finally figured it out. Someone must've replaced or removed either the distributor or the oil pump at some point and never bothered to take the engine to TDC. I cranked the motor until I got cylinder 1 to TDC, removed the distributor cap, and looked at where the rotor was pointing. My new firing order for all intents and purposes is 241536. Retarded. I appreciate the help guys. I was so sure it was the wrong cap/rotor until sblake01 posted. Oh well. Link to comment https://www.classiczcars.com/forums/topic/28416-car-wont-start-after-tune-up/#findComment-250743 Share on other sites More sharing options...
June 14, 200816 yr comment_250756 The second picture is from a 1972 l24.... mine to be precise. The first pic is from a "77 280, mine to be precise Thanks for the loan of your pic in my previous thread. Link to comment https://www.classiczcars.com/forums/topic/28416-car-wont-start-after-tune-up/#findComment-250756 Share on other sites More sharing options...
