I just replaced worn bushings on the trailing arms and put back the front sway bar from Suspension technique with urethane bushings.
On small bumps at low speed, the front end squeaks...
Is it beacuse of the urethane bushings???:ermm:
https://www.classiczcars.com/forums/topic/28442-noisy-sway-bar/
Suspension Techniques urethane products come with a small packet of silicone grease-the grease goes in every metal to urethane contact. The grease is available from autoparts stores-at least in my area.
Will
You can also drill holes and tap them to accept zerk fittings. Then just drill a corresponding hole in the bushing itself so that you can lube them regularly. Teflon tape and lube only last so long, being able to add more lube without taking the thing apart is a good idea.
Zerk fittings: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93541
No. I figured the bar would spread it around. Not a bad idea though!
EDIT-- I should also say that I called Energy Suspension and they said normal moly grease was fine for use with poly bushings.
WEll, I've put some grease, and dawn it... it is not doing any good...
Hope I wont have to remove the sway bar and start over again..
When I press on either of the front corner I can hear that funny squeaky noise, like squick squick..
Annoying.. tonight, I went for a small ride, people were looking at me... and wondering what was that noise..
Any quick fix.. ?
Guest
Reply to this topic...
