Posted June 18, 200816 yr comment_251179 How much does it cost to use a DYNO, not an engine Dyno but the kind where you strap the car on it and let it run?Jus like to know how much HP some upgrades will make ove stock.~Z~ Link to comment https://www.classiczcars.com/forums/topic/28469-how-much-does-it-cost-to-use-a-dyno/ Share on other sites More sharing options...
June 18, 200816 yr comment_251188 WingZr0 said: How much does it cost to use a DYNO, not an engine Dyno but the kind where you strap the car on it and let it run?Jus like to know how much HP some upgrades will make ove stock.~Z~Horsepower Freaks/Torque Freaks is a dyno and aftermarket specialist in Portland. They put on "Dyno Days" every once in awhile, where you can come and run your car on their rollers for about $35. Link to comment https://www.classiczcars.com/forums/topic/28469-how-much-does-it-cost-to-use-a-dyno/#findComment-251188 Share on other sites More sharing options...
June 18, 200816 yr comment_251217 Thats pretty cool...I'd never heard of them. Where are they located in the Portland area?Greg Link to comment https://www.classiczcars.com/forums/topic/28469-how-much-does-it-cost-to-use-a-dyno/#findComment-251217 Share on other sites More sharing options...
June 19, 200816 yr comment_251219 They're on airport way. Head east away from I-205 until you'd turn right to go to Costco. Instead, turn left, and they should be right there on your left.Check 'em out here www.horsepowerfreaks.com Link to comment https://www.classiczcars.com/forums/topic/28469-how-much-does-it-cost-to-use-a-dyno/#findComment-251219 Share on other sites More sharing options...
June 19, 200816 yr Author comment_251291 JonnyRock said: Horsepower Freaks/Torque Freaks is a dyno and aftermarket specialist in Portland. They put on "Dyno Days" every once in awhile, where you can come and run your car on their rollers for about $35. Freaking Awesom! 35 bucks!, Thats pretty cheap I heard or read somewhere it was $500 which I thought was rediculous, thyanx. Any one know of any Dynos in the Sacromento, CA area by chance or Bay Area? soundmasterg said: Thats pretty cool...I'd never heard of them. Where are they located in the Portland area?Greg You of theam all the time on Horse Power TV, the Speed Channel and in most magazines. Dsport, (see my signiture below), speaks of them all the time. The best numbers are the ones broken down into "wheel" Horse Power and not the numbers refering to power made at the flywheel instead. After all its the power to the ground that matters. I mainly want to see what some of the more simlple MSA upgrades will do like the aluminum radiator and electric water pump and high capacity oil pump. As wells as a header test like the old 6 into 2 versus the 6 into 1 debate backed with solid numbers for a change, unless thats already been done :cheeky:. ~Z~ Link to comment https://www.classiczcars.com/forums/topic/28469-how-much-does-it-cost-to-use-a-dyno/#findComment-251291 Share on other sites More sharing options...
June 19, 200816 yr comment_251295 Dyno time is typically $100 an hour with a one time charge of $50 for the first strap down.The $35 deal is for 3 pulls only most likely. Link to comment https://www.classiczcars.com/forums/topic/28469-how-much-does-it-cost-to-use-a-dyno/#findComment-251295 Share on other sites More sharing options...
June 19, 200816 yr comment_251298 WingZr0 said: The best numbers are the ones broken down into "wheel" Horse Power and not the numbers refering to power made at the flywheel instead.After all its the power to the ground that matters.~Z~A wheel dynamometer would measure power at the wheels, and then use an equation assuming 15% or so powertrain loss to determine Brake Horsepower (power at the flywheel).An engine dyno would do just the opposite.BTW: That 15% varies depending on many factors. Link to comment https://www.classiczcars.com/forums/topic/28469-how-much-does-it-cost-to-use-a-dyno/#findComment-251298 Share on other sites More sharing options...
June 19, 200816 yr comment_251308 Thanks for the info Jonnyrock, I'll checking into them.Greg Link to comment https://www.classiczcars.com/forums/topic/28469-how-much-does-it-cost-to-use-a-dyno/#findComment-251308 Share on other sites More sharing options...
