June 24, 200816 yr comment_251799 Sweet Jeebus! Everything there is just friggin perfect. Clean, Shiny, Color-coded. It sure is nice. I'll trade you a Klondike Bar for it!! Link to comment https://www.classiczcars.com/forums/topic/28527-new-l-28-goes-in-the-1970/?&page=2#findComment-251799 Share on other sites More sharing options...
June 24, 200816 yr comment_251806 Much envy...nice work.. Link to comment https://www.classiczcars.com/forums/topic/28527-new-l-28-goes-in-the-1970/?&page=2#findComment-251806 Share on other sites More sharing options...
June 26, 200816 yr comment_251942 I took some pix tonight with the air filter hooked up. Looks and runs amazing!!!! My dad did an outstanding job.<a href="http://www.flickr.com/photos/14049800@N00/2612559530/" title="IMG_9287 by RVAE34, on Flickr"><img src="http://farm4.static.flickr.com/3203/2612559530_d63d3b38d9_b.jpg" width="1024" height="683" alt="IMG_9287" /></a><a href="http://www.flickr.com/photos/14049800@N00/2612557646/" title="IMG_9285 by RVAE34, on Flickr"><img src="http://farm4.static.flickr.com/3080/2612557646_8d2d55fe0c_b.jpg" width="1024" height="683" alt="IMG_9285" /></a><a href="http://www.flickr.com/photos/14049800@N00/2611722439/" title="IMG_9284 by RVAE34, on Flickr"><img src="http://farm4.static.flickr.com/3008/2611722439_84a7cdb694_b.jpg" width="1024" height="683" alt="IMG_9284" /></a> Link to comment https://www.classiczcars.com/forums/topic/28527-new-l-28-goes-in-the-1970/?&page=2#findComment-251942 Share on other sites More sharing options...
June 26, 200816 yr comment_251981 Quick question -- where did you guys get the rubber seals for that early air cleaner box? I have one as well, but need to get the rubber seals for it. Link to comment https://www.classiczcars.com/forums/topic/28527-new-l-28-goes-in-the-1970/?&page=2#findComment-251981 Share on other sites More sharing options...
June 26, 200816 yr Author comment_251984 Try Bruce Palmer at Z Therapy......They sell reconditioned Air Boxes......Everything they do is AAA+......even if he does drive a station wagon! Link to comment https://www.classiczcars.com/forums/topic/28527-new-l-28-goes-in-the-1970/?&page=2#findComment-251984 Share on other sites More sharing options...
June 16, 200915 yr comment_286945 This is just achingly beautiful... really its mindboggling how pristine everything...You sir, have me green with envy Link to comment https://www.classiczcars.com/forums/topic/28527-new-l-28-goes-in-the-1970/?&page=2#findComment-286945 Share on other sites More sharing options...
June 17, 200915 yr comment_286950 Holy schnikes! That is the best looking stock engine bay I've ever seen. Fantastic work Guy! Link to comment https://www.classiczcars.com/forums/topic/28527-new-l-28-goes-in-the-1970/?&page=2#findComment-286950 Share on other sites More sharing options...
July 13, 200915 yr Author comment_289466 It would be very interesting to get a wide-band A/F meter/recorder on that engine - then dyno tune it... Would be interesting to see if the SM's are too rich.... I've seen several reports that they are - but it would be good to see a direct comparison with supporting dyno runs..(on the same engine, same day, same dyno etc).Everything sure looks great...FWIW,Carl B.Carl......We did the dyno test with the SM's and an A/F meter and recorder. I'm not an expert, but my friend doing the dyno said the A/F was absolutely perfect through the entire rpm band. The only area it was running slightly rich was at idle. W/O the air cleaner we were running slightly lean at 7,000 r.p.m. I've got the chart on A/F if you need to know any specifics at different rpm. His comment was that even fuel injection doesn't run a better A/F than the L28 did! Guy Link to comment https://www.classiczcars.com/forums/topic/28527-new-l-28-goes-in-the-1970/?&page=2#findComment-289466 Share on other sites More sharing options...
July 13, 200915 yr comment_289468 Nice job!What did you guys do to finish the valve cover like that? I am wondering what the best way is to restore to stock standards.Thanks,Marty Link to comment https://www.classiczcars.com/forums/topic/28527-new-l-28-goes-in-the-1970/?&page=2#findComment-289468 Share on other sites More sharing options...
July 13, 200915 yr comment_289473 Your efforts came out so perfectly that it doesn't look real! Without question you've raised the bar to the top. Hat's off to you. Link to comment https://www.classiczcars.com/forums/topic/28527-new-l-28-goes-in-the-1970/?&page=2#findComment-289473 Share on other sites More sharing options...
July 13, 200915 yr comment_289475 Carl......We did the dyno test with the SM's and an A/F meter and recorder. I'm not an expert, but my friend doing the dyno said the A/F was absolutely perfect through the entire rpm band. The only area it was running slightly rich was at idle. W/O the air cleaner we were running slightly lean at 7,000 r.p.m. I've got the chart on A/F if you need to know any specifics at different rpm. His comment was that even fuel injection doesn't run a better A/F than the L28 did! GuyGuy,Thanks for the report on those dastardly SM needles. We know they run fine and have since first used in '73. I'd like to see a companion run done on the dyno using the stock needles for comparison.Over all, great job!! Where'd you say you got those carbs again?? Nyuck nyuck Link to comment https://www.classiczcars.com/forums/topic/28527-new-l-28-goes-in-the-1970/?&page=2#findComment-289475 Share on other sites More sharing options...
July 13, 200915 yr comment_289478 Where'd you say you got those carbs again?? Nyuck nyuckSubtle as a wagon driver....But one day I'm calling you guys up for carbs... Link to comment https://www.classiczcars.com/forums/topic/28527-new-l-28-goes-in-the-1970/?&page=2#findComment-289478 Share on other sites More sharing options...
