mgood Posted June 24, 2008 Share #1 Posted June 24, 2008 I did a quick search and did fine some info. on the fuseable links for the 280, I was wondering if the parts could be purchased at a Nissan dealer and if any one knew the part numbers. I noticed this weekend that the plastic coating on the black one in my car is cracked not burnt just cracked. thanks, Link to comment Share on other sites More sharing options...
sblake01 Posted June 25, 2008 Share #2 Posted June 25, 2008 24161-A0100 is the part number for the 80 amp-1.25mm2. Not sure if Nissan still carries them. If you can't find any, I have a few good spares. Link to comment Share on other sites More sharing options...
webdawg1 Posted June 25, 2008 Share #3 Posted June 25, 2008 The following url should help you out some...http://www.zzxdatsun.com/280z_stuff.htmlwebdawg1 Link to comment Share on other sites More sharing options...
sblake01 Posted June 25, 2008 Share #4 Posted June 25, 2008 Hey, webdawg, I recall fixing your links in the past. You must have something in your user cp that prevents urls for parsing properly in your posts. http://www.zzxdatsun.com/280z_stuff.html Link to comment Share on other sites More sharing options...
mgood Posted June 25, 2008 Author Share #5 Posted June 25, 2008 Thanks to all, that is what I am looking for. Link to comment Share on other sites More sharing options...
webdawg1 Posted June 25, 2008 Share #6 Posted June 25, 2008 Sblake01,I've looked around in my settings...did not see anything that would turn on/off the url funtion. (I.E. - Have always done a copy paste from IE to posts in the past and it has never came up as a clickable link) Over at http://www.zcar.com when I do a copy/paste for a url it does show up as a clickable link...go figure...webdawg1 Link to comment Share on other sites More sharing options...
sblake01 Posted June 25, 2008 Share #7 Posted June 25, 2008 In the user CP, in Edit Options, down in the Miscellaneous Options area in the Message Editor Interface, are you using Standard editor-extra formatting controls? Link to comment Share on other sites More sharing options...
webdawg1 Posted June 25, 2008 Share #8 Posted June 25, 2008 Ok...lets see if it works now...I changed it to standard editor-extra formatting controls? Never even knew that was even in there......Hello... http://www.atlanticz.ca/ webdawg1 Link to comment Share on other sites More sharing options...
