I haven't driven the car much since the engine rebuild, in fact only had it broken in on a dyno then a track day and drove it from one side of atlanta to the other.
I recently sold the car but have been working on some title issues, that we finally cleared up, and on friday, I moved the car out of the garage to do some other work and it started fine, on saturday, when I went to take it on a proving run before its long drive to the new home, I couldn't start it.
It cranks for a second or two, lights off for about 2 revolutions and dies.
Its an L28 with SU carbs,
any ideas?
https://www.classiczcars.com/forums/topic/28532-car-wont-start/
Have you checked to make sure the fuel filter isn't clogged?
If it kicks over just a bit maybe one carb is clogged. if you pull the spark plugs you can tell by the color if it is firing or not.
Maybe a weak spark? What kind of ignition?
I'm pretty new here and it sounds like you know what you are doing so I apologize if these sound really obvious, and/or beneath your experience level:)
Just wondering... what brand & number plugs are you using? In my several L24's the only plugs that worked well were NGK (BP6ES or BPR6ES). Champion, Bosch, etc., would foul relatively quickly for me - that's been my experience anyway, and I'm confident that there are others that will agree.
I agree with the NGKs , but the motor should at least run with the new plugs regardless which brand they are. Maybe not to its potential . Champions bit the dust when installed in my engine. My PO ''tuned her up" LOL I barely made it home.
Gary
