Posted June 25, 200816 yr comment_251917 replacing power steering lines on wife's mustang. it was leaking red fluid which i presume is transmission fluid. should i replace with power steering fluid or should i use tranny fluid that was in it to start with? thankyou very much in advance. Link to comment https://www.classiczcars.com/forums/topic/28540-power-steering/ Share on other sites More sharing options...
June 26, 200816 yr comment_251955 Not trying to sound d!ckish, but what does the owner's manual instruct?I have a 76 BMW that requires brake fluid for not only the brakes, but the power steering, as well. Link to comment https://www.classiczcars.com/forums/topic/28540-power-steering/#findComment-251955 Share on other sites More sharing options...
June 26, 200816 yr comment_251962 It's been a while since I had to add fluid to my power steering unit, but I used to use regular ATF.Someone else chime in and correct me, but Power Steering Fluid IIRC is simply re-packaged ATF.E Link to comment https://www.classiczcars.com/forums/topic/28540-power-steering/#findComment-251962 Share on other sites More sharing options...
June 26, 200816 yr comment_251973 I agree with you on that "E".Rick. Link to comment https://www.classiczcars.com/forums/topic/28540-power-steering/#findComment-251973 Share on other sites More sharing options...
June 26, 200816 yr comment_251993 I apologize, I was wrong. I checked the BMW. The CLUTCH uses brake fluid. The power steering has tranny fluid. DUH! Link to comment https://www.classiczcars.com/forums/topic/28540-power-steering/#findComment-251993 Share on other sites More sharing options...
June 26, 200816 yr Author comment_251999 It's been a while since I had to add fluid to my power steering unit, but I used to use regular ATF.Someone else chime in and correct me, but Power Steering Fluid IIRC is simply re-packaged ATF.Ei'm guessing ATF means automatic tranny fluid , but what does IIRC stand for? Link to comment https://www.classiczcars.com/forums/topic/28540-power-steering/#findComment-251999 Share on other sites More sharing options...
June 26, 200816 yr comment_252004 If I Recall Correctly Link to comment https://www.classiczcars.com/forums/topic/28540-power-steering/#findComment-252004 Share on other sites More sharing options...
June 27, 200816 yr comment_252103 Transmission fluid takes more heat and holds up better. At least that's what I've been told, I've always run it in all my cars w/ power steering w/ no problems. Link to comment https://www.classiczcars.com/forums/topic/28540-power-steering/#findComment-252103 Share on other sites More sharing options...
