replacing power steering lines on wife's mustang. it was leaking red fluid which i presume is transmission fluid. should i replace with power steering fluid or should i use tranny fluid that was in it to start with? thankyou very much in advance.
https://www.classiczcars.com/forums/topic/28540-power-steering/
It's been a while since I had to add fluid to my power steering unit, but I used to use regular ATF.
Someone else chime in and correct me, but Power Steering Fluid IIRC is simply re-packaged ATF.
E
E
i'm guessing ATF means automatic tranny fluid , but what does IIRC stand for?
