Skip to content
MAF mounting with Summit Radiator
Let me start by saying that if you are thinking of saving some money and going with the Summit Racing aluminum radiator, dont. I have already spent enough that I could have purchased the one from arizona z car, and I still dont have it done. If you want the details of what has been involved so far, send me a PM, but trust me when I say it is not worth it. The latest issue is that the water inlet neck is right next to the mass airflow meter. By removing the mounting plate, I can make enough room to get the hose on the inlet neck. In order to mount it back onto fenderwell, I will have to make some major modifications to the bracket. I would prefer not to destroy the mounting bracket just to make this thing fit. My question is this: Would it be ok to let the intake couplers hold the MAS in place? It is held in place pretty well by the hoses, but I figured Nissan mounted it solidly for a reason. Will vibration be an issue? Will it work?
I think it would be better to mount it solidly. The extra movement of it just being mounted by the hoses might cause the hoses to wear. Oh, and it's not a MAS, simply and AFM (Air Flow Meter). And being a AFM rather than a MAFS, it's much heavier and would probably put extra stress on the hoses. Our cars EFI systems weren't sophisticated enough to have a MAFS.
