Posted July 1, 200816 yr comment_252575 My A/T has been redone two weeks ago. A new transmission mount has been installed this week.It seems that I have weak engine mounts because my A/C compressor bracket is stuck on the left frame rail with no clearance as before.I have the new engine mounts but the transmission shop is charging me $200.00 to install them. It doesn't seems to be a big job.Has anybody has a safe procedure to do this work or is it better to bring the car to other shops to ask for a quote? Link to comment https://www.classiczcars.com/forums/topic/28616-replacement-of-engine-mounts/ Share on other sites More sharing options...
July 1, 200816 yr Author comment_252576 I forgot.....it is a 240Z Link to comment https://www.classiczcars.com/forums/topic/28616-replacement-of-engine-mounts/#findComment-252576 Share on other sites More sharing options...
