Posted July 2, 200817 yr comment_252646 filled up ,drove home,next morning wont stay running Link to comment https://www.classiczcars.com/forums/topic/28624-what-happened/ Share on other sites More sharing options...
July 2, 200817 yr comment_252649 Guessing that it ran well prior to the fill up, my first thought is that your filter is clogged or you got some bad gas. If you have a transparent fuel filter look and see if there is any water in the filter.If you can not do that undo your gas line where you can run some gas into a glass jar and again look for water.If there is no water, you may want to replace the filter.The next thought is that you have something that has now decided to block the pick up in the gas tank. If that is the case you will have a whole new set of questions maybe.These are what come to mind based on you just filling up the tank. Good luck.Barrie Link to comment https://www.classiczcars.com/forums/topic/28624-what-happened/#findComment-252649 Share on other sites More sharing options...
July 2, 200817 yr Author comment_252652 the fuel pump is loud humming noise .i think it has chunk of rust somewhere.hope it is just that Link to comment https://www.classiczcars.com/forums/topic/28624-what-happened/#findComment-252652 Share on other sites More sharing options...
July 2, 200817 yr comment_252654 We need more info. Link to comment https://www.classiczcars.com/forums/topic/28624-what-happened/#findComment-252654 Share on other sites More sharing options...
July 2, 200817 yr comment_252659 If it has a 'chunk of rust' somewhere, a fuel filter won't really help. You'll ultimately need to clean the tank or have it cleaned. Extra fuel filters are just a bandaid. My car had the same problem when I first purchased it. I did the extra filter for about a week and when it clogged again, I replaced the tank. 10 years later, no extra filter but more importantly, no problems. Link to comment https://www.classiczcars.com/forums/topic/28624-what-happened/#findComment-252659 Share on other sites More sharing options...
