Posted July 2, 200816 yr comment_252647 small filter next to tank on return line from previous owner,why? Link to comment https://www.classiczcars.com/forums/topic/28625-78-280-z-fuel-filter/ Share on other sites More sharing options...
July 2, 200816 yr comment_252648 no idea why it would be on the RETURN line. that makes no sense. putting it on the output line in between the tank and pump though, that helps keep tank crud out of the pump if you have tank rot Link to comment https://www.classiczcars.com/forums/topic/28625-78-280-z-fuel-filter/#findComment-252648 Share on other sites More sharing options...
July 2, 200816 yr Author comment_252650 i am goint to put one between tank and fuel pump Link to comment https://www.classiczcars.com/forums/topic/28625-78-280-z-fuel-filter/#findComment-252650 Share on other sites More sharing options...
