Posted July 2, 200816 yr comment_252661 had the car 4 months put new dist. cap rotor ,fuel filter,fuel pump,plugs,wires,vacuum lines,frt.brakes,rear wheel bearings so far.it was running fine til fill up Link to comment https://www.classiczcars.com/forums/topic/28627-fuel-problem-78-280z/ Share on other sites More sharing options...
July 2, 200816 yr comment_252665 Sounds like you have provoked the RUST monster... Would check out the condition of your fuel tank first...Z fuel tanks are real bad about rusting inside. Let us know what all you find in there...pictures...etc...etc. webdawg1 Link to comment https://www.classiczcars.com/forums/topic/28627-fuel-problem-78-280z/#findComment-252665 Share on other sites More sharing options...
July 3, 200816 yr comment_252673 Did your car sit for a while before you bought it? If so, you're lucky to get four months out of it. Mine sat for four years and really wouldn't run right until I dealt with the tank. The EFI cars get it a little worse than the carbed cars but in either case you'd be better off cleaning out the tank. Link to comment https://www.classiczcars.com/forums/topic/28627-fuel-problem-78-280z/#findComment-252673 Share on other sites More sharing options...
