Posted July 6, 200816 yr comment_252807 Pulled out a Hitachi radio model no. KMS-3611B. This has an 8-pin connector using all 8 pins, and a 6-pin connector using 5 pins. I'm trying to find out what exactly these thirteen wires are.I downloaded a previous wiring diagram, but it only shows where 8 of the wires go. If anyone has a complete diagram, it would be extremely helpful! Link to comment https://www.classiczcars.com/forums/topic/28644-1983-280zx-radio-wiring-desperately-needed/ Share on other sites More sharing options...
July 6, 200816 yr comment_252808 from a 79, but I don't think the radio wiring changed. Is the unit you mention the original or an aftermarket piece?Body_Electrical.pdf Link to comment https://www.classiczcars.com/forums/topic/28644-1983-280zx-radio-wiring-desperately-needed/#findComment-252808 Share on other sites More sharing options...
July 6, 200816 yr Author comment_252810 The stereo in there now is the original 1983, I'm trying to replace it with an aftermarket CD player Link to comment https://www.classiczcars.com/forums/topic/28644-1983-280zx-radio-wiring-desperately-needed/#findComment-252810 Share on other sites More sharing options...
July 6, 200816 yr comment_252817 In 83 there were two different stereo systems depending on whether you had a non GL, or a GL model.Non GL.bmpGL.bmp Link to comment https://www.classiczcars.com/forums/topic/28644-1983-280zx-radio-wiring-desperately-needed/#findComment-252817 Share on other sites More sharing options...
November 24, 200816 yr comment_267323 I have got the wiring connected to my speakers and only here a low sond level? Anyway to incrase the volume. It is turned all the way up? Link to comment https://www.classiczcars.com/forums/topic/28644-1983-280zx-radio-wiring-desperately-needed/#findComment-267323 Share on other sites More sharing options...
