Was having alternator trouble with my 280 and like a fool disconnected the negative cable while running to confirm alternator. Car has not started since. I have spark and fuel to the rail. If I spray a shot of starting fluid in the intake it will start. Did i fry something by removing the cable??. My injectors do not click at all while turning over. Any thoughts on this would be greatly appreciated.Thank you in advance, Tim
https://www.classiczcars.com/forums/topic/28671-76-z-fuel-only-to-rail/
I seem to be having the same problem with my car, starts with starting fluid and thats it. I downloaded the Fuel Injection manual and printed it out a couple days ago.
http://www.atlanticz.ca/zclub/techti...ectionbook.pdf
Here is a link, looks to be very well written and might help you out. I am only now to the troubleshooting section.
