Posted July 10, 200816 yr comment_253270 When i shut the car off the engine will sound like fuel is still igniting in it. Not sure what the problem is. its a 260z w/ the orginal L26 and 70 round top SU's Link to comment https://www.classiczcars.com/forums/topic/28701-problem-with-sus/ Share on other sites More sharing options...
July 10, 200816 yr comment_253271 Sounds like dieseling. Not a carb problem. The carbs are just reacting to what the engine is doing.Can be from timing being too far advanced, too high compression ratio, carbon build up on the pistons or a combination of these..... Link to comment https://www.classiczcars.com/forums/topic/28701-problem-with-sus/#findComment-253271 Share on other sites More sharing options...
July 10, 200816 yr Author comment_253272 could be carbon build up since the engine is completly stock and has never been rebuilt or as far as i know really worked on at all. Link to comment https://www.classiczcars.com/forums/topic/28701-problem-with-sus/#findComment-253272 Share on other sites More sharing options...
July 10, 200816 yr comment_253273 There is a product called Sea Foam that is supposed to do a fair country job of cutting carbon build-up from pistons. You might want to check with your local parts house and give it a whirl..... Any of you guys have first hand experience with Sea Foam?? Link to comment https://www.classiczcars.com/forums/topic/28701-problem-with-sus/#findComment-253273 Share on other sites More sharing options...
July 10, 200816 yr comment_253277 try moving to a higher octane fuel as see if that clears it up. Link to comment https://www.classiczcars.com/forums/topic/28701-problem-with-sus/#findComment-253277 Share on other sites More sharing options...
July 10, 200816 yr Author comment_253282 bigoak said: try moving to a higher octane fuel as see if that clears it up.I will try that as right now i am running regular 87 octane in it Link to comment https://www.classiczcars.com/forums/topic/28701-problem-with-sus/#findComment-253282 Share on other sites More sharing options...
July 10, 200816 yr comment_253297 Too high of an idle, or a engine that's running hot will do that. Link to comment https://www.classiczcars.com/forums/topic/28701-problem-with-sus/#findComment-253297 Share on other sites More sharing options...
July 11, 200816 yr comment_253327 Or potentially your timing is to far advanced. Check it out! Link to comment https://www.classiczcars.com/forums/topic/28701-problem-with-sus/#findComment-253327 Share on other sites More sharing options...
